Re: Texman Build
Thanks Gulf for the flue help!
I really need some guidance and advice as to whether i should add a thermal break in the floor on the entryway. The picture attached shows my current situation.
Just poor planning on my part. I can cut three of tiles on the wetsaw since they are not attached. But the other two are where the arch sits and will have to be cut with a circular saw and diamond blade, i guess. I think the blade will cut this firebrick. I havent tried it but i can test to be sure. But even at full depth, the saw will leave around 1/4" of the cut since the blade is not big enough to cut full thickness of the floor. i can manage that with the angle grinder i think. But no margin for error on the two under the arch.
i dont think they should crack and i am fairly confident of a straight cut. But is all really worth it at this point? How much performance gain do you guys think the thermal breaks are adding to the overall oven performance? I am thinking of the same type as Deejay and aidan using stainless and ceramic rope to separate brick from steel. Seems like the rope is doing the work and the stainless is more for appearance. I like the stainless look, just trying to understand. Also, i am not convinced of the benefit of the heat break at the inner arch to outer arch contact because of all the heat of the gas. Since heat rises and is stored in the dome, doesnt that mean the thermal floor breaks are less effective also?
Thanks for any and all help.
Tracy
Tracy
