Re: Texman Build
That sounds like a good plan. Its good to know where you are going on this project.
Originally posted by texman
View Post
) I will begin the dome curve on the third course. Thanks again for looking and for all the great guidance you left for all of us.
I found out what kind of brick layer i am and also that i need to be a better one in places. i also learned the importance of consistent mortar mix, moist bricks and compression of the mortar joints to remove voids. I am using Alsey flue set and the mortar needs to be used within 15 minutes of mixing, after 15 minutes, the mortar will not compress to achieve consistent mortar joints. As a newbie, i think i should have mixed some test batches and then taken them apart to see what a good joint looks and feels like.
