Re: Texman Build
That's correct Tracy. In your case the shortest line to the centre would be the lower edge - so the each succeeding row would tend to overlap the lower one slightly - but as you say wrong grip on the clamp etc can also cause similar effects.
Most of us would prefer to not know exactly how bad a bricklayer we are - completed domes hide a multitude of sins
I found the few times I relaid bricks that I had to do them 4 or five times - scraping off the mortar each time before I was happy - so I was not so fussy in the end.
Looks pretty good - how do you find building the arch as you go. It was the first thing I did and I found it useful to have something stable to butt each course up against - but others prefer that method.
The proof of the tool accuracy is when you start the next course above the previous angled course. If it doesn't line up with the top inner edge of the brick below, the tool is off.
I found out what kind of brick layer i am and also that i need to be a better one in places.
should have known that since i could see it as i set them.
