Re: Texman Build
I built the arch this weekend and set course 4 and started course 5. I was happy with the results of my labor thus far, until i was posting pics this morning. I was looking at the pictures of the arch and saw the droop.
I have literally spent hours reading threads to avoid it, and here i am infected with it. It would be tonight before i could remove any bricks, so i dont think i want to do that (mortar really set by then) I will go back and study the lessons i thought i had learned from the ones that mastered the droop and see if i can both figure out what i did wrong as well as how to fix it now.
I still think i did good on the arch.
Getting better with the mortar too.
I am checking level in these pictures as you can see. Pretty good, but slightly lower on the right when facing the oven.
I didnt even see that droop till i was looking at the pictures. It is sneaky.
Tracy
I am using the steel pieces to hold brick in place (when i mix mortar too wet)
learning...
(i could build a pretty good oven if i started over now
Tracy
learning...
