Re: Texman Build
I built the arch this weekend and set course 4 and started course 5. I was happy with the results of my labor thus far, until i was posting pics this morning. I was looking at the pictures of the arch and saw the droop.
I have literally spent hours reading threads to avoid it, and here i am infected with it. It would be tonight before i could remove any bricks, so i dont think i want to do that (mortar really set by then) I will go back and study the lessons i thought i had learned from the ones that mastered the droop and see if i can both figure out what i did wrong as well as how to fix it now.
I still think i did good on the arch.
Getting better with the mortar too.
I am checking level in these pictures as you can see. Pretty good, but slightly lower on the right when facing the oven.
I didnt even see that droop till i was looking at the pictures. It is sneaky.
Tracy
I am using the steel pieces to hold brick in place (when i mix mortar too wet)
learning...
(i could build a pretty good oven if i started over now
Getting better with the mortar too.I am checking level in these pictures as you can see. Pretty good, but slightly lower on the right when facing the oven.
Tracy
learning...
