Re: Perth 42" Pompeii - dome to flat entry integration
Just use your indispensable tool to check if your dome will connect with your arch. If it doesn't reach correctly than you will end up with a teardrop like some of us have. The arch has to be pushed far enough into the oven to make a good connection.
- I had this problem in my build, you can check it out if you want.(round shape)
Good luck,
Mike
Good luck,
Mike
