First Timer's AZ Build
Re: First Timer's AZ Build
Now, if you mean how to set the veneer brick across the open span, that's another question. You can make another arch, or put a support over the span and mortar the bricks to the block and adjacent bricks, or make something more complicated like a basketweave or other design. I'd probably gonwith the flatter arches.
I finally finished up the lentil construction - see pics below. As you can see with the second picture, the angle iron was exposed to the inside, rather than the outside face. I wanted to have as clean a face as possible for the brick veneer.
Next step is researching the hearth design and pour. Considering a slot for the ash, but not going to do it- most say that it isn't needed. Anyone have strong opinions on the subject?
Working on my wooden stand for the hearth pour a couple of nights ago.
Not sure if the shims recommended are for the base of the 2x4s to level out (my assumption), or for when you place the plywood on top of the 2x4 frame.
I am using a 5/8 inch particle board that is one solid piece (well one piece that I will rip down the center so that I can remove once the hearth is poured). Keeping a 3/8 gap between frame and blocks as suggested.
[QUOTE=Phxdt;132154]I finally finished up the lentil construction - see pics below. As you can see with the second picture, the angle iron was exposed to the inside, rather than the outside face. I wanted to have as clean a face as possible for the brick veneer.QUOTE]
I think FB plans call for the lintel (not the bean) to have angle iron front and back. I'm not sure you will have enough support for the slab with the angle iron on only one side of your lintel.
If you are concerned about having the brick facing be flush to the lintel then grind the front of the block back a bit so it can be recessed
I will say that all the messy grinding + the cost of the angle iron was the reason I chose to pour my lintel with the slab.
-The Shims are to help remove the supports after you pour. If they are perfectly cut and put in there it's too hard to pull them out. The shims give you a little wiggle room.
-I would overbuild every support for the pour. Look at other builds, You can't stop moving cement.
Good Luck
Originally posted by Phxdt View PostI am using a 5/8 inch particle board that is one solid piece (well one piece that I will rip down the center so that I can remove once the hearth is poured). Keeping a 3/8 gap between frame and blocks as suggested.Last edited by azatty; 06-13-2012, 06:53 AM.
Azatty,
Given any thought of using Durock or Handiboard and just leaving in the pour. I used this type of material in my hearth pour and it makes a clean interior. They show it as an option in the Pompelli Plans.
RussellRussell
If I were to do it again, I would probably use backer board and leave it. The oven fairies poured my slab while I was out of town, and didn't give much thought to how to remove the supporting wood. So I ended up having to cut out 1" plywood with a jigsaw AFTER the piece fell down from the bottom of the slab a year later.
Well, I ended up making Father's Day weekend my time to pour the hearth. I rented the largest concrete mixer I could find ( 9 cubic feet capacity), so I only needed to mix two batches. I used a plywood support with no backer board in the end. I had it purchased, and took it back.
For someone who has precious little experience pouring concrete, it turned out very well. I am going to focus on bricking up the facade while it cures to max strength. Progress photos below of my saturday pour.
I might wait on putting any finish material on until you finish the dome. I found that making the dome was a pretty messy project. The concrete work looks good to me. My first pour was a horrible looking slab.
I salute you, though, for braving the insane temperatures we're experiencing. When I was building mine last year, I had already quit working for the season by June.
