Re: Chirobuggy's 42inch oven build5
The bricks are cut in half (roughly) for the first 4 - 6 rows and then need to be cut in smaller pieces ( usualy 3) for higher rows.
I do not have access to my files right now so will send you something tonight or tomorrow.
But here are the dimensions. 42 inch diamater inside dome, 13.75 high X 21.75 Wide inner arch, 14.75 high X 22.5 wide flue arch, 12.5 inch deep on the flue arch with an additional 3 inch veneer of decorative brick.
My inner arch is a little high for the "IDEAL" 63% of dome height at 65.48 but it seems to work well and I was considering putting in some soapstone like John has "giannifocaccia" so ?I wanted to have the ability to add thickness if I needed it and still stay close to the ideal door height.
I used the method of cutting my inner arch bricks described by many builders, that of having the inner arch bricks reach back into the oven as they get higher.
My post "Chip's 42 in Minnesota" and "Octoforno" by giannifocaccia
and several others describe this technique. I think it is the best way to do your inner arch.
Chip
Originally posted by chirobuggy
View Post
Chip
