42" Pompeii in S. Louisiana
Re: 42" Pompeii in S. Louisiana
I like the door reveal detail you cut into the vent brick...clean look.Old World Stone & Garden
John Ruskin
This afternoon, I started mortaring the oven bricks with home brew. After I finished for the day, I noticed cracks along some of the bricks. I dipped the bricks in water for about a minute and used a chip brush to wet the mating surfaces. Is this anything I should be concerned about?
Nope...carry on.Old World Stone & Garden
John Ruskin
I made some progress on my build today set the second course and had much better luck. Buttered all surfaces with a very thin layer of mortar (this allows complete adhesion of all surfaces) than apply enough mortar to allow for the joint size expected. I recommend the smallest size joints possible. I'm using Demon High heat mortar max joint size 1/4"Originally posted by Kurtloup View PostThis afternoon, I started mortaring the oven bricks with home brew. After I finished for the day, I noticed cracks along some of the bricks. I dipped the bricks in water for about a minute and used a chip brush to wet the mating surfaces. Is this anything I should be concerned about?
With the mortar bricks covered in plastic to retain moisture, this allowed me to push the mortar into cracked joints. I went back and on compress mortar with trowel for a crack free joint. The longer you can retain the moister the easier it is to repair those cracks and separations.
I think maybe just a little to large of mortar joint. Try getting them a little tighter or spacing them with scliced masonry wedges.Originally posted by Kurtloup View PostJoe Watson " A year from now, you will wish that you had started today" My Build Album / My Build
Looks great, nice build!!
....lol
