Congratulations Kurt,
That is a BIG milestone. Curing fires are imminent . I would love to visit and see the finished oven some day. Maybe, you could invite me and Tu for the christening .
Look's Great Kurt,
I'm not sure that the two small sections of form (above your arch) need to be removed, since they don't actually touch the arch. But, I think that the void could be filled by "tuck pointing" (with more vcrete) if they needed to be .
I'm looking forward to your finished oven .
Did you drop some steel into the hearth? I wouldn't expect a whole lot of shear strength from the vermiculite. May not be an issue, I have no clue of the load.
Steel up from the hearth into the vcrete? No. Rebar in the hearth, yes. I made the assumption that the vcrete has enough compressive strength to withstand any outward pushing of the arches when the exterior brick is laid next to the vcrete. The force will have to displace the exterior brick too. I'll have the weight of a 2' clay flue (about 45 lbs.) and enough exterior brick to cover the flue supported by the arches.
That sounds a lot like my approach. I dropped some steel through the cores of the exterior brick. The concern isn't compressive, it's the side load. If you think it may be an issue you can address it when you get to that point - looking good!
