42" Pompeii in S. Louisiana
Re: 42" Pompeii in S. Louisiana
Put on the base coat of stucco on the dome today and noticed a few cracks already. Is this a big deal since I will be adding at least two more layers? Should I consider using fiberglass mesh in the brown coat? The insulation was covered with chicken wire.Last edited by Kurtloup; 08-04-2013, 04:42 PM.
Originally posted by Kurtloup View PostOh well, can't seem to attach the video using my phone.
I actually saw the video this morning. But, it was linked to an album. I'm not sure if was your album or just links to similar
videos.
Originally posted by Kurtloup View PostShould I consider using fiberglass mesh in the brown coat? The insulation was covered with chicken wire.
One tip that I found out on my dome for applying stucco to a compound curve. I used a 12" sheet rock taping knife to apply the stucco. They are pre-built with a curve in the blade. I did not use the handle when applying the stucco. I buttered the blade with the stucco and held each end of the blade while applying. Top down seemed to work best for me to keep the shape of the dome true.
EDIT: I'm enjoying your first cooks. I am pretty sure that I will be asking for recipes from you real soon .Last edited by Gulf; 08-04-2013, 05:37 PM.Joe Watson " A year from now, you will wish that you had started today" My Build Album / My Build
Yeah, I was planning to use home brew for final coat. I used quikcrete base coat stucco this morning. I did see the quikcrete mix with fiberglass fibers. I may try that on the next level in lieu of the mesh. If all else fails, I'll brick over it.
Your video worked - it's pretty cool to watch isn't it? When you go full throttle (fires of hell), get a bottle of wine and a front row seat. Watching the soot burn to the floor is awesome the first time you see it.Check out my pictures here:
Get your sourdough starter going and fire it up. Cracks add character.....just ask my wife.Greg Geisen
Chula Vista, CA
Click to see my Thread:
http://www.fornobravo.com/forum/f8/g...iego-6169.html
Click to see Google web album:
http://picasaweb.google.com/gpgeisen...eat=directlink
Originally posted by Kurtloup View PostI'm in the process of sourcing fire bricks and what I have found through multiple phone calls and leads from two of the local forum members is two fire bricks are available within 75 miles of my house. I can get light duty Elgin Butler brick 5 miles from my house for $1.80 or Alsey medium duty in New Orleans for $2.15 and a tank of gas. I'll be using the oven more for pizza than bread baking, so it appears that the medium duty bricks are recommended from what I have read on the forum. Since I'd like to keep the build as inexpensive as possible, I am leaning towards vermiculite/cement insulation. However, in the big scheme of the build, the brick and insulation is a small cost. I'd appreciate any pros and cons of the two types of bricks and insulation. Thanks in advance.
Kurt
I am headed to port allen to get my ceramic blanket, thanks to you
Yesterday morning, I welded a kabob holder for a football game watching party last night. It worked great. I ordered the steel for an insulated door and a chimney cap on Friday. Since there was a minimum order, they will cut the steel to size. That will save me a lot of time.
Nice. Kebabs yummy
