Like most people I have been hanging around for a while and gathering information.
I have now been handed the perfect excuse to build a WFO
I bought a house with a retaining wall that the previous owner had part built and intended to finish with a set of steps to the rear of the property.
But I had a better idea and convinced the other other half that it would be a cheaper option to build an oven in the wall.
I put in a foundation and built a corbeled stand before the winter drove me inside. Now spring is here I have poured the base and started planning a layout. The 39 is a compromise between 36 and 42.
The oven will be enclosed in a house with a roof and chimney to look like a mini version of the cottage. The bricks that will finish the job are hand thrown and reclaimed from my chimney and a bread oven. The house was a butchers and bakers years ago so it seems fitting to reuse what I can.
I have attached a few photos and will try and keep this thread updated as much as possible. It seems only fair, that in return for all the info I have obtained from this site, that i let future users learn from my mistakes - of which I expect a few
I would appreciate any questions and criticism to help me along.
My first question (there will no doubt be a lot more to follow) is
I am lucky enough to have the use of a diamond wet brick saw,the sort you normally see on site and have to pay to rent from tool hire companies, and am planning on tapering my bricks as i don't have to rush the job.
I estimate on using 210 but don't want to under order. Has anyone built an oven this size this way and got a better estimate?
Thanks for all the help so far - this site has been a huge help.
Andrew.
Andrew.
