30"/760mm Scotland Pompeii
    • 5263
    #136
    Re: 30"/760mm Scotland Pompeii
    I have always like the European chimney pot and originally wanted to place one on my oven but never figured how to get one back on the plane back to the US.
    • jms
      • Feb 2013
      • 78
      #137
      Nice solution for the cap. You could slurry coat the top of the cap for a smoother finish.
      I'm planning to render it in the same way I render the plinth. Haven't decided on a finish yet.
      This pot was ?40/~$70 and it looks like shipping it to the US would be another $70. I wonder if it would survive transit .
      Today I put a chimney cap on. Had to modify it a bit by bending and shortening the metal straps to make it fit better. Cost ?25 from ebay.
      • jms
        • Feb 2013
        • 78
        #138
        Today I moved the canopy aside and started the normal curing schedule. Goodbye to my clean brickwork
        The side walls reached 150c/300f after a couple of hours and I kept it there by feeding more briquettes for a few more hours. Tomorrow I'm going to start it early and try to get it a bit hotter all day, and then move onto wood the next day.
        Does anyone have experience getting old permanent marker out of firebrick?
        • deejayoh
          • Jul 2010
          • 1893
          #139
          That looks awesome. You should be very proud
          900 degree fire should do the trick...
          • jms
            • Feb 2013
            • 78
            #140
            Since the last post I've completed the dome brickwork and finished with a concrete plug. I had wanted to wait until I'd fired the oven a few times (to drive any possible moisture out), but it has been raining every other day and firing it means I have to move the canopy. I decided that just getting it waterproofed and able to fire it without worrying about rain is more important.
            • jms
              • Feb 2013
              • 78
              #141
              Then I got the final brick cutting out of the way. Just straightening stuff to make it look better once it is pointed.
              • jms
                • Feb 2013
                • 78
                #142
                Then I started pointing and got the arch done. Just a simple white sand/white cement mix.
                  • 2848
                  #143
                  G'day
                  That outer coating of brick will go a long way to waterproofing the oven. But you still have the Achilles heel of any oven in the open and that's the hearth at the entrance. That hearth brick will soak up any rain that falls on in. It will wick into your oven and of course your insulation will soak it up real fast. A tarp laid on the hearth is a good enough temporary measure, but a outer door is what you'll want in the long term.
                  • jms
                    • Feb 2013
                    • 78
                    #144
                    G'day
                    Yep, I'm planning on building an outer door for this reason.
                    Did some more pointing today, finished the chimney and started on the dome.
                    • jms
                      • Feb 2013
                      • 78
                      #145
                      I've finished pointing over the last two days.
                      Next I've got to clean it up. I've also started buying pizzamaking supplies.
                        • 3884
                        #146
                        Very nice looking oven .
                        • jms
                          • Feb 2013
                          • 78
                          #147
                          The first products of the oven.
                          Caputo 00 dough (20hrs bulk fermented, 6 hrs balled, both at room temp), San Marzano sieved tomato sauce, mozzerella, chorizo. Made 6.
                          • jms
                            • Feb 2013
                            • 78
                            #148
                            Banana and Confiture de Lait (Milk Caramel sauce) dessert pizzas. Made 2.
                            Next time I need to go hotter and build a bigger bed of embers. I aimed to not overload the oven this first time, but I know it can higher to get that really spotty effect on the crust.
                            • jms
                              • Feb 2013
                              • 78
                              #149
                              I've made up my weatherproofing door over the last few days. The wood was part of an old tabletop, sanded down, and four coats of varnish. With a couple of handles and a weathersealing strip around it.
                              • jms
                                • Feb 2013
                                • 78
                                #150
                                I've finished cleaning the oven brickwork. I just wish I'd done it before the mortar set and then it wouldn't have taken a couple of days.
