Is the home depot vermiculite good?
  • Tscarborough
    • Oct 2009
    • 3341
    #16
    Re: Is the home depot vermiculite good?
    The difference is not small, David, it is almost double for open VS closed cell foams.
    • stonecutter
      • Jun 2007
      • 2003
      #17
      You can't compare R values of foam to perlite. I could easily use that surface area reasoning to say a cavity filled with sand is a better insulator than course gravel...and I doubt that.
      What I'm saying is that R-vaule is determined not just by size of the material but what the material is made of. A perlcrete slab made with fine perlite is closer to a solid mass than a slab that is made with course perlite.....period. So in my mind, fine grains will not insulate as well as course grains, because of the conductivity of the cement in the slab.
      I find it impossible to see how fine grade perlite will have a higher R-value because of this. Air is a poor heat conductor compared to solid material.
      However, I am not so stubborn that I can't see the possibility that fine grade may have an edge over course...simply by functioning by trapping more heat by not having the larger cavities.
      Conversely, do the finer particles conduct and transmit more heat because they are more densely packed? This is a possibility too.
      I have a feeling we are splitting hairs. But I can guarantee you one thing....course perlite is not as dusty to work with.
      Old World Stone & Garden
      John Ruskin
      • martin_80x
        • Aug 2013
        • 13
        #18
        1 part - Type I/II portland cement ( not pre-mix containing sand or masonry cement)
        6 parts perlite or vermiculite.
        I will do that then, but what confused me was the getting started thread, which says concrete mix in the drawing.
        http://www.fornobravo.com/forum/f6/h...sophy-693.html
        • martin_80x
          • Aug 2013
          • 13
          #19
          I don't have lots of experience but, I've seen hearts in South America composed by broken glass and salt, or even beer bottles .
          • stonecutter
            • Jun 2007
            • 2003
            #20
            I've seen that too, along with clay earth mixed with sawdust.
            We do this occasionally...and I love it. A good discussion ( without getting bent out of shape) will just make you a better builder....and a better forum user.
            John Ruskin
            • stonecutter
              • Jun 2007
              • 2003
              #21
              Because it has the components of concrete - Portland cement, aggregate and water.
              John Ruskin
                • 9216
                #22
                That may be true for open vs closed foam cells which have different surface properties. But small vs large grains of vermiculite have similar surfaces.
                  • 9216
                  #23
                  I've not seen any published data on the relative insulating values of fine vs coarse vermiculite so it may be up to us to conduct some tests. I don't have any of the fine stuff on hand, but may try to get a bag next time I need more. Then make up some samples and test them. I'd also be quite interested to see the difference between the insulating values of 5:1 vermicrete and 10:1, so could also include samples of eac of these in the test.
