Re: 42" Pompeii Oven in Virginia
Dino's build pretty much outlines the tapered entry but I am talking about the inner tapered arch which may have evolved after Dino's build. A tapered inner arch will make the dome to inner arch much a smoother tie-in. Dino's tapered entry is great but no reason why you cannot incorporate the taper inner arch as well. Your build is at the right transition point to do this.
