42" Pompeii Oven in Virginia
1 PhotoCheck out my pictures here:
If at first you don't succeed... Skydiving isn't for you. -
Re: 42" Pompeii Oven in Virginia
I don't think many I have seen have been built with a cut like your photo, Les. Most people finish the inner arch and then build the entry a bit bigger to create the reveal You have to build it that way if you want a heat break between the dome and entryComment
Jon, the build looks great! I haven't heard of any cons to it. Seems like the right place to fit the door.Link to my build
http://www.fornobravo.com/forum/f8/4...nia-19904.html
Link to my pictures
https://plus.google.com/photos/10871...CPfMh4SMmcnQAQComment
KB thanks...I am anxious to get into the arch. I should get to cement the rest of the entryway bricks this morning.Link to my build
Link to my pictures
Les, your reveal cuts are the same as Dino's, whose plan I'm following.Link to my build
Link to my pictures
Gudday
Build your oven entranceway bigger than the oven door and you will always have a "lip" to seal an oven door ...and you'll have a greater opening to operate your oven through. It doesn't matter how deep its about how wide.
Regards daveMeasure twice
http://www.fornobravo.com/forum/f28/...ock-17190.htmlComment
I saw flue liners when I went to buy more bricks yesterday and I think I bought the wrong clay flue liner. I bought 8.5x8.5 and I'm seeing 10" on here for a 42" oven. Correct?Link to my build
Link to my pictures
10"....you can't over flue an oven..Old World Stone & Garden
John RuskinComment
Thanks Stonecutter! Oh, the other question that I had was whether an 8" round was equivalent to a 10" square/rectangle? I'd see if Allied Concrete has a precast square to round transition.Link to my build
Link to my pictures
err... no!
10" square has a flue area of 100 square inches, 8" round has only 50 square inches. Almost exactly half!Last edited by boerwarrior; 10-18-2013, 08:59 AM.Comment
I know that
I thought I read somewhere, however, that the efficiency of a round flue was greater than that of a square or rectangular flue.
Link to my build
Link to my pictures
Round flues are more efficient, but that is more important for inside fireboxes and chambers ....outside, larger flues are better.Last edited by stonecutter; 10-18-2013, 09:18 AM.Old World Stone & Garden
John RuskinComment
To calculate the effective size of a flue, the I.D. is used for a round flue, for a square flue a circle is drawn inside and that is considered the effective area of the flue, so a 10" square flue is 78.54, a round 8" is 50.265. What is the inner arch opening size, that is the guiding dimension, not the size of the oven.Comment
Thanks! I'll see what they have and go 10" square if they have it, 8" round otherwiseLink to my build
Link to my pictures
Allied has 12 x 12 and 8.5 x 12 pipes, but they also have an 8" inside diameter thimble which is 18" in height. I think I'll get a couple of these. With the roofline, I may need three.Link to my build
Link to my pictures
