42" Pompeii in Paso Robles Ca.
  • Yes to cool to under 100 degrees it will take me 10 days or more. But I make pizza and the next day I will be at 700F if I don't do bread and scrub a bunch of heat out first then day 3 is still 600F plus. I have not done any cooking past this point. But with temps below 0 I am still at 200 degrees now on my 8th day.
    Randy
    • Very well done!
      My build documentary page:
      • Originally posted by RandyJ View Post
        Randy
        Ok well Randy, you are the first guy that I have read about that get's more than 5 days of heat. So now I am on a mission. The one thing I don't have is vermiculite in the enclosure. that could really help it is clear.
        For now I just have the dome inside an empty cavity simply because I thought 5 days was about as good as it got. So here is what I have.
        3 inches Ceramic Blanket
        2 inches Forno Fiber Board
        1 inch stucco or as thin as .5 in - this is covering the blanket.
        4 inch Forno Fiber Board - Sheet metal door.
        The door really changed the game for me. So now I guess I will fill the cavity with perlite etc.
        Do you have any other insulation items to mention? I would love for day two and 3 to be hotter than I am getting.
        Darin
        • Well there are a few things I did slightly different than you.
          1. I did 4"of ceramic board under the oven.
          2. I wanted to be a little higher so I put patio stones under the insulation to raise it a little. I think this might also act as a little heat break.
          I also have 3" of blankets.
          3. I put 36 cf of vermiculite over the top of the insulation. So it is between 6" and 18" thick depending on where you look.
          I also did all the heat breaks. Dome and floor
          Randy
            Randy
            What did you do for your door?
            • Opps sorry about that. The door is 4" thick filled with ceramic board. 22 gage for the inside and sides, and 16 gage for the outside. I also put a ceramic rope around the edge as a gasket. I painted it with a high temp stove paint. It seamed to be holding up well so far.
              Randy
                Randy
                Ok so that is the same as mine.
                So the only thing that I cannot do is add 2 inches of insulation to my floor. but If I get a couple more days, that will be a complete success.
                I really want 3 days of solid heat. Sounds like the perlite in the cavity might get me close.
                • If you can try to block off the corners. I did not do that, but bet I could have saved a few bags if I did. It is suprising how much of it it takes to fill the void in the enclosure. Good luck I hope that helps with your heat retention.
                  Randy
                    Randy
                    Seems like it would be easy to use some styrofoam or cheaper insultation to fill the voids a bit.
                    • Yeah something like that. I was going to use cement board to block the corners, but got in a hurry and forgot all about it.
                      Randy
                        Randy
                        Randy how did you hold the rope to the door? And what type of rope? Where did you get it?
                        • I got the ceramic rope from menards in the wood stove area. It was a door seal replacement kit and came with the glue. I think it was about 8$. The paint I used also came from there rated for 1200F and seams to be holding up nicely so far.
                          Randy
