90cm (35-36 inch) Pompeii style oven in Slovenia
  • kanoer54
    • Apr 2013
    • 137
    #31
    Re: 90cm (35-36 inch) Pompeii style oven in Slovenia
    Beautiful oven build! You will be cooking in that oven shortly. I think i can smell it over here already. keep posting pictures.
    Jon
    jon
    • artman
      • Mar 2014
      • 15
      #32
      Hello, i was curing oven and in the last step of curing, big fire the dom has crack, from botom talmost to top, and in the top araund the dom. From outside i can see the flames in the oven. What to do? Can i fill crack with mortal or the dome is broken. I m so angry. I will post a picture when i com to home.
      By
        • 2848
        #33
        G'day
        It's pretty hard to be the first to answer your post.
        Your angry and disappointed , but you'll find that as that cools it will drop back to position. It will probably open up again when the oven is heated again.
        Will it fall down ? No! Will it cook as it should. Yes !
        Its a wood fired oven, some do crack but they still work as they should. You have built a dome, one of the strongest things on the planet . It will even stay together with the heat trying to push it apart cause gravity pushes it back.
        They are others that will have had the same.
        • gorazdr
          • Apr 2014
          • 48
          #34
          Artman sorry to hear about your crack, but it seams that is quite common. Thinking back perhaps you made a mistake mortaring first course to the ground?
          Bye, Gorazd
          • Greenman
            • Feb 2013
            • 1123
            #35
            Artman, you were on a high speed roll as well. All is not lost. If you want to see/read the pics and wisdom offered for such a dilemma then have a look at this.
            You will realise that you are not alone and in fact there are probably more ovens with some level of cracking than not.
            Cheers ......... Steve
            • artman
              • Mar 2014
              • 15
              #36
              Hi,
              long time no post, sorry.
              My oven is finished, i insulating the dome (5cm of rock wool), cover it with cicken wire and stuco it. I installed the chimney.
              The first pizza was perfect, taste of crispy crust, melted chess, and ham. Yust incredible, so incredeble that i forget to picture it. Floor was 320c or 640F and the dome was 420 c or 840F. Bake time 1 minute and half.
              That day i bake 6 pizzas, and all was perfect and teasty.
              Next day i bake in a ceramic pan a pork meat and the sliced potato, on top i put carot and onion. Potato was so soft and melty, and the pork, yust youuuhuhu. Njami. I youst forget to picture it. Sorry.
              In saturday i have a party so i will post a pictures of pizzas.
              Insulating in my oven is for mi ok, the oven stay hot 2 days. 1. day in morning 180 c or 360 F, 2.day 70c or 140 F.
              The cold oven is prepered to cook pizza in 90 minutes of fire.
              I also made from leftower wood a table and the bench.
              by
              • GarnerAC
                • Jul 2013
                • 242
                #37
                Well done! Amazing what some good food can do to lift spirits. What size is your vent pipe? Looks a little too small. Is it too late to increase the size of it?
                My build documentary page:
                • artman
                  • Mar 2014
                  • 15
                  #38
                  Hi,
                  GarnerAc - vent size, do you mean chimney, its 13 cm or 5 inch. Yes is to small but that pipe i have at home. I can resize it to 16 cm or 6,3 inch (maybe later). But chimney is 2.5 m or 8.2 feet hight. So the draft is ok, but after the fire gone and ther is alot of smoke, some goes throu the openings. no big deal..
                  by
