Re: 7 years in the waiting i get to start my 42" pompeii
Great progress, Lee. The slate is going to look awesome.
thank you carl and steve. the roof took a few hours this morning as well as yesterday to finish the cuts going into the fascia beam took a long time to do the beam had to be notched out with a chisel. And the supports all had to be chopped in an L style angle type cut to lock into the beam the 2 pics hopefully show this
all in all 213ft linear of timber has gone into this roof a lot of weight but its as solid as hell ive done the walk test and my joiner pal has done me proud
I gave in and got a roofer to come and give me a price to lay the slate and all the lead work. I have the tiles so, labour, lead , copper nails and lathe all supplied ?950 with 2 chimneys to lead around said it would take 3 days max or go at it myself for weeks decisions to make.
Very impressive.
Lookin' good, Lee!!
hi guys Ive got myself a week off this week to crack on with the roof ,made some good progress today with the help of a joiner friend Im using treated 9x2 for all the inside frame work and some sleepers that still have the bark on top and bottom with a rough cut face for the front 3 fascias they measure around 9x4 to hopefully blend in with the posts and give an old style look. we notched the bottoms out so they sit in to the post and mitre cut them to give a better look from the front here are the pics from the day still a lot more supports to put in as yet
thanks Carl yes I am really happy with how its turning out the end is near! ive been on that ebay again and scored a lovely fire grate with pan stands that swivel in and out the fire for skillet work and boiling it arrived yesterday so I went and got my block splitter and got the hearth floor done so I could get it in there couldn't help myself so I got a little tester fire going
I do want to clean the grate up and paint it up but il need to do some research on the right product if im going to eat off itLast edited by leetheldc; 06-11-2015, 07:03 AM.
That's quite an impressive project you have there, Lee. You should be very happy w/it. Soon, you'll be cooking and will be able to sit back and enjoy all the hours of work you put into it. Congrats!!
Originally posted by NCMan View PostLooks like it'll be time to crank that beauty up soon, Lee.
I got the fireplace /bbq chimney finished today so I have a matching pair happy smile topped out
I also got some half bricks on the fireplace floor for an edge later filled the inside with a vermiculite mix at around 8 to 1 with some white cement I had left over from the day I got a thickness of 70 mm leaving it down form the top of the brick 75mm giving a 10mm bed for my firebrick floor I will go with the herringbone layout for that
thanks a lot Carl much appreciated well here is another update for ya.
I locked my twin wall to the anchor plate and used this sealant I used for the heat break to set it in placeI then cut2 collars from the blanket and pushed them down around the twin wall to insulate to anchor plate and the firebrick you can just see it here
I then laid the paver on some 30mm up right pieces of paver to make it look abit more substantial the paver on its own just looked a little thin the twin wall just pops out the topI used some fire rope around the twin wall collar top stop the mortar from pushing on the rim when I layed the chimney pot
you can see in this pic it worked il try to get some sealant in there later or just pull it out if I cant get in at itil get the firplace one the same tomorrow and cast some form of crown on top of the paver
It looks like you are on your way, Lee. You've done your homework and are making great progress. It's going to look and function great!! I always look forward to your updates.
Originally posted by NCMan View PostLee.......I am not personally experienced w/a pumice flue liner, although I did look them up. It seems they work just fine, although insulating the air gap is recommended w/them, as I understand it. I think they would work fine, but if you feel more comfortable w/the double walled stainless and don't mind the price difference, maybe go w/that. I imagine that whatever you decide, it will work fine. Best of luck!!
Hi guys has any of you used a pumice chimney liner or know of someone who has. Im just weighing them up against a twin wall they are alot cheaper but I want full belt and braces and worry about it crackng so should I just stick to the stainless twin wall to be safe? The money doesn't really bother me at this stage
That'll be nice to get it watertight. Thanks for keeping us all up to date w/your progress.
