42" Build Underway in Central Alabama
  • #46
    Re: 42" Build Underway in Central Alabama
    More photos:
    Third chain completed
    Completed template for inner arch - lots more figuring to go for the dome to arch transition...
    • #47
      Here is a link of how a tapered arch is done that is similar to yours. It is from GF and Mr. C.
      • #48
        http://www.fornobravo.com/forum/8/oc...tml#post119582
        Thank you -- that is very helpful.
        • #49
          Wish I had tapered my arch bricks like that. Russell, I'm certain that would have made crossing the arch a hole lot easier.
          Chris
          Link to my photo album:
          • #50
            Chris,
            Your build turned out very nice anyway, especially liking the slate roof.
            • #51
              Another photo update:
              Redneck (I use that term proudly) canopy:
              More figuring for the arch:
              • #52
                Keystone for arch - I had to mortar two brick together to get the dimensions I wanted:
                • #53
                  Working on spacing for the arch (smiley face = teenager humor):
                  • #54
                    Complete arch:
                    • #55
                      Looking good! Nice progress.
                      My Build:
                      • #56
                        I've been trying to wrap my mind around the best way to keep my bricks from sliding when I get to the courses with steeper angles. I've seen several different solutions others have used. I decided to try making a "clip" to put over the brick (surely someone has done this before - but I couldn't find any related posts).
                        I had some Simpson Strong-Tie straps left over from a previous project. I bent them to snap over the brick - and hold against the back side of the brick on the course below.
                        It was so simple and easy, I decided to post photos here:
                        • #57
                          As the courses get steeper, I should be able to hang a weight from each clip to hold the brick in place:
                          • #58
                            Ummm, nice innovation to the string and weight method.
                            • #59
                              Well, the "brick clips" worked very well. In fact, I didn't need to use weights until the next to last course.
                              The only caveat was when a violent thunderstorm blew up unexpectedly. Afterward, I noticed that a couple of brick had shifted (leaned)...but the mortar was well set by the time I discovered this. I didn't see that it was bad enough to chip them out for a redo, so I left them like that.
                              • #60
