42" Build Underway in Central Alabama
Re: 42" Build Underway in Central Alabama
Here is a link of how a tapered arch is done that is similar to yours. It is from GF and Mr. C.
http://www.fornobravo.com/forum/8/oc...tml#post119582Comment
Thank you -- that is very helpful.Here is a link of how a tapered arch is done that is similar to yours. It is from GF and Mr. C.
Wish I had tapered my arch bricks like that. Russell, I'm certain that would have made crossing the arch a hole lot easier.Here is a link of how a tapered arch is done that is similar to yours. It is from GF and Mr. C.
http://www.fornobravo.com/forum/8/oc...tml#post119582Chris
Link to my photo album:
Link to my build: http://www.fornobravo.com/forum/f21/...nia-19366.htmlComment
Chris,
Your build turned out very nice anyway, especially liking the slate roof.Comment
Looking good! Nice progress.My Build:
"Believe that you can and you're halfway there".Comment
I've been trying to wrap my mind around the best way to keep my bricks from sliding when I get to the courses with steeper angles. I've seen several different solutions others have used. I decided to try making a "clip" to put over the brick (surely someone has done this before - but I couldn't find any related posts).
I had some Simpson Strong-Tie straps left over from a previous project. I bent them to snap over the brick - and hold against the back side of the brick on the course below.
It was so simple and easy, I decided to post photos here:
Ummm, nice innovation to the string and weight method.Comment
Well, the "brick clips" worked very well. In fact, I didn't need to use weights until the next to last course.
The only caveat was when a violent thunderstorm blew up unexpectedly. Afterward, I noticed that a couple of brick had shifted (leaned)...but the mortar was well set by the time I discovered this. I didn't see that it was bad enough to chip them out for a redo, so I left them like that.
