Re: Out of work Pizza Man's 42" Build in NJ
Five degrees may or may not matter in your build, depending on how tight you want the joints. Being off five degrees at the start could carry through your whole dome.
I see that you are using an IT which will help to control that - but I am not sure about your IT design. The axis of your IT should hit right at the middle of the brick in each course. Your IT design hits at the top of the brick. That will result in each course being slightly steeper than it should be, will eventually affect your dome.
See this thread for a better explanation
