My first attempt for 42" oven / changed to 36"
  • George_M
    • Oct 2014
    • 290
    #121
    Re: My first attempt for 42" oven / changed to 36"
    Hi,
    I plan to put the floor plates like the first photo.
    I think that will be ok.
    I need more space to put the bricks on the floor (second photo),so i think to put bricks at high arch distance, like the third photo,so the bricks will build on it.
    Which is your opinion?
    Also,in the floor corners,i have free space.Can i leave it as they are to avoid cutting in arch?
    In my last photo you can see the compare of insulation layer fro the first day and today. I think is dry.Can i put the floor on Saturday or i need to leave it more days to dry?
    • stonecutter
      • Jun 2007
      • 2003
      #122
      Originally posted by George_M
      Hi,
      You can build on the hearth brick. Setting the floor on the inside of the dome would make changing hearth brick easier, but firebrick is pretty much a lifetime install on occasional use home ovens.
      It's hard to say if your insulation is dry based on a picture, because of the variables involved. If you really want that layer to dry faster, take the forms off.
      Old World Stone & Garden
      John Ruskin
      • Tonyp
        • Jan 2009
        • 165
        #123
        Hi George,
        You can trace the wood outline on the floor bricks and then cut them to fit inside the dome and entry. You can then build the dome and entry on top of the perlcrete.
        The alternative would be to extend the floor bricks a little bit so the dome sitting on top doesn't overhang the floor. When you build in this method typically you trim the floor bricks so they don't stick out too much beyond the dome, but a little bit won't hurt and you won't see it once the outside of the oven is insulated and finished.
        Tony
        Link to my oven build thread:
        40 inch indoor pompeii in NNY
        • George_M
          • Oct 2014
          • 290
          #124
          I want to avoid to cut in arch the floor plates because i haven't any other tools except the angle grinder and i don't know how easy will be.
          The other solution is to cut the plates like the photo.
          • stonecutter
            • Jun 2007
            • 2003
            #125
            To repeat, you CAN build your dome right on top of your hearth brick. It's not an inferior method....unless you're using soft biscotti tile or junky brick.
            Build away.
            John Ruskin
            • George_M
              • Oct 2014
              • 290
              #126
              Thanks stonecutter!
              I will build on the hearth brick and i will cut the floor plates like the photo.
              It will be better for the insulation with ceramic blanket because will enclose it inside.
              If i don't cut the edges will be outside from the ceramic blanket.Bad idea..
              • George_M
                • Oct 2014
                • 290
                #127
                Hi,
                Today i removed the wood frame from the perlcrete to fast the dry proccess.
                I will put it again if i start the floor to avoid any damages in the perlcrete.
                Also,i try to cut two bricks to test the blade.It cuts very nice but i have problem to cut straight.
                I made a base to align the blade while i cut the bricks.I didn't test it yet but i think will help me to cut straight the bricks.
                • Laurentius
                  • Nov 2010
                  • 923
                  #128
                  Hi George,
                  Did you download and study the Pompeii plans, and are you modifying as you build? I thing by trying to reattach your frame probably do more damage than your building the oven on it.
                    • 9216
                    #129
                    Hi,
                    George,
                    Try to allow that vermicrete to dry really well (I'm talking weeks not days) before building over it. Removing the water from an under floor vermicrete slab takes a long time to do it with fires.
                    • George_M
                      • Oct 2014
                      • 290
                      #130
                      Originally posted by Laurentius
                      Hi George,
                      Yes,but i missed something?
                      If you mean for the frame,i didn't remove it permanently yet.Just for drying.
                      Also,i disassembly it in the two corners to avoid damages when i put it again.It is looks like two "L"
                      Originally posted by david s
                      George,
                      David i will let it dry more of course,i didn't start the floor yet.
                      • George_M
                        • Oct 2014
                        • 290
                        #131
                        Hi,
                        Today i try to cut the bricks in the frame which i made for straight cutting.
                        I cut the bricks much better than without it.
                        I soaked first in water and i cut it very easy.
                        Also,two weeks now,the weather is sunny and the temperature almost 20 oC!
                        It helps to dry the perlcrete.
                        • Tonyp
                          • Jan 2009
                          • 165
                          #132
                          Woo looks like you are just about ready to start construction! The cutting looks fine to me. It sure helps to soak the bricks first for sure!
                          Tony
                          • George_M
                            • Oct 2014
                            • 290
                            #133
                            I wait for this time.hehehe
                            I see photos from other ovens and i have a question.
                            In the first row did you put mortar between floor and brick?(or under the brick and up to the floor)
                            Or need only left and right of the bricks?
                            Look my attachment what i mean.
                            • Tonyp
                              • Jan 2009
                              • 165
                              #134
                              Hi George,
                              The floor is not mortared to the first row, so only mortar on the sides.
                              Tony
                              • George_M
                                • Oct 2014
                                • 290
                                #135
                                Hi,
                                Do you know the perlite durability in high temperautres?
                                Is it strong enough when the temperature is high?
