My first attempt for 42" oven / changed to 36"
Today we finished the dome!!!
I need your advise for the vent construction.
My plan is to build a half arc with opening inside.
Like this oven:
https://community.fornobravo.com/fil...photoid=282884
But i need some information for the height.
Must be more high than my inner arc or The same?
I saw both method constructions and i don't know witch is the correct method.
You should make your vent arch the exact same shape but larger than your inner arch. This is done to leave a reveal for your insulated door to fit snug against.Joe Watson " A year from now, you will wish that you had started today" My Build Album / My Build
