Nathan's 36" SoCal WFO build
    • 9208
    #136
    Re: Nathan's 36" SoCal WFO build
    Originally posted by n8huntsman
    Any thoughts on those cracks? Going to be time to insulate it shortly.
    I presume you did the drying fires with the oven uninsulated. Doing it this way results in a bigger difference in outside temp and inside temp which leads to stress. You probably also went at it too fast. No point in crying over spilt milk. I'd be squishing in some homebrew into the cracks and also building up a layer over the top of the crack, then proceed with the blanket.
    • Novaslo
      • Dec 2013
      • 279
      #137
      I agree, use a very liquid type home brew and get those cracks filled to give you piece of mind. Ultimately, I doubt that it will be structural problem.
      Start cooking and then don't look back.
      • n8huntsman
        • Jan 2014
        • 143
        #138
        One interesting thing to note is that all of the separations of the mortar from the brick are on the non-buttered side. I'm left handed so when I hold the brick in my right hand, I butter the bottom and left side of the brick then set it in place. All of the cracks are on the top and right sides of the bricks. For some reason it seems I don't get as good of adhesion on the side that I'm sticking the brick to. I guess pressing the mortar into the brick with the trowel adds to the adhesion. Does anybody butter both sides or "back-butter" as I've heard it called?
        http://n8sbar.servebeer.com/
        Oven Thread
        Kitchen/Bar Thread
        • n8huntsman
          • Jan 2014
          • 143
          #139
          I took a grinder and ground out the biggest cracks. Remortared them then wrapped the dome in 4" of CF blanket. After that things were kinda lumpy and I needed a way to conceal my 1/2" EMT that leads out of my thermocouple J-box. I decided to use a couple inches of vermicrete to do so. I assume that if I tried to lay stucco (render) scratch coat that thick it would crack. Probably would have been fine using some other type of mortar but I figured the added insulation wouldn't hurt. Wow, this vermicrete stuff is a PITA! Once I'm done with the extra vermicrete can I go directly to scratch and brown, continuing to keep things moist or should I do some sort of drying of the vermicrete before trying to do the scratch and brown. I know that needs to be kept moist too so I don't see what it would hurt to do it all at once, let it cure then do the final color coat of stucco??
          Oven Thread
          Kitchen/Bar Thread
          • Greenman
            • Feb 2013
            • 1123
            #140
            I agree, vermicrete is like trying to render with wet puffed rice - only more difficult! I developed a place and smear technique that seemed to work but I found it was something to do and leave alone. Messing with it was courting trouble!
            There is no reason to wait to start the stucco/render process. It would be a good idea to give the vermicrete time enough to set properly and the top to dry a bit before messing with it just so it maintains its integrity. The stucco coat will allow moisture to escape, just need to leave it until the whole thing has dried before the sealing coat.
            Cheers ......... Steve
            • n8huntsman
              • Jan 2014
              • 143
              #141
              Planning on finishing up the vermicrete and getting the scratch coat and possibly the brown coat of stucco down this weekend. I know the stucco is supposed to be kept wet. Does that mean that trying to cook a couple pizzas this memorial day would be a bad idea? With 4 inches of CF blanket and 2" of vermicrete, not sure how much heat will actually make its way to the stucco...
              Oven Thread
              Kitchen/Bar Thread
                • 9208
                #142
                Leave your vermicrete layer at least a week to dry before adding the stucco layer. As vermicrete consists of a third of its volume as water there is lots to dry. As your oven is under cover the layer is not going to see any sun so drying may take longer. if you don't allow it to dry you risk cracking the stucco layer when the water in the insulation layer turns to steam. You can still use the oven to cook with in the meantime and the fires will help it dry. When you think it's dry throw some plastic over it to see if any water condenses under the plastic.
                • n8huntsman
                  • Jan 2014
                  • 143
                  #143
                  With everything except the stucco and some stonework done, Im switching back to my kithen/bar thread: http://www.fornobravo.com/forum/f35/...ild-20331.html
                  Ill post the final pics here too when Im done in a few weeks. Thanks to everyone who has helped make the oven a success as far as I'm concerned! Couldn't have done it without you guys.
                  Oven Thread
                  Kitchen/Bar Thread
