Re: Nathan's 36" SoCal WFO build
I presume you did the drying fires with the oven uninsulated. Doing it this way results in a bigger difference in outside temp and inside temp which leads to stress. You probably also went at it too fast. No point in crying over spilt milk. I'd be squishing in some homebrew into the cracks and also building up a layer over the top of the crack, then proceed with the blanket.
Originally posted by n8huntsman
View Post
