Siporex as insulation?
  • Mullins
    • Apr 2014
    • 86
    Hi guys,
    Has anyone heard of using Siporex as insulation under the oven floor? I am an English speaker in a French/German speaking country so finding it difficult to find some materials.
    On a French forum I saw oven builders (pizza and bread ovens) use a product called Siporex, which appears to be an insulating concrete with air pockets.
    What I can find out about the product is below. How would this compare/perform when compared to Calsil board?
    "Thermal Conductivity: The thermal conductivity (?k? value) for completely dry Siporex of density 550kg/m3 is 0.144 W/m?C. The air bubbles trapped in Siporex are giving10 times better insulation properties compared with conventional dense concrete. This is reflected in considerable savings of electricity consumption and improved indoor comfort."
  • Laurentius
    • Nov 2010
    • 923
    Re: Siporex as insulation?
    Originally posted by Mullins
    Hi guys,
    "10 times better insulation properties Compared with conventional dense concrete", has no merits as a thermal insulator! You can not compare them in your oven building, they have nothing in common!
      • 9216
      You can compare the thermal conductivity of the two materials here
      Calcium Silicate Insulation
      It shows Cal sil is around twice as good.
      • Mullins
        • Apr 2014
        • 86
        Thanks Daviid,
        Can you explain it to me? the lower the K value the better the insulator is?
        From what I have seen also the CalSil can get compressed from the weight of the oven on top of it. Is vermicrete the best option to have a hard/solid under floor insulator?
        Mullins
          • 9216
          Thanks Daviid,
          Mullins
          Correct, lower k value= better insulator.T cal sil will not compress because the load is spread. Same applies with 5:1 vermicrete.
