Re: 42" Idaho spud
David, both are very valid points. I've thought about drilling holes in the basin. I wondered if they would allow moisture in from below though. Although, the storage areas under it should be dry usually. As for the slope, I did slope it away ever so slightly. And, I will be doing a framed enclosure and will further seal against water where the walls of the enclosure meet the slab.
Thanks, Alex
Thanks, Alex
