Re: Acoma 42" Tuscan
I just finished the third row, right side arch wall. I plan to wait a couple days then get the left side built. I will be doing the forth row of each side carefully, since I have to cut into the bricks on the forth row to allow the arch to be built. I originally believed I would do the wall and two courses of dome by end of this Sunday, but I started thinking that the Arch completed should be first, then to start building the dome up. Doing the arch wall is such a delicate matter, I took longer than I originally thought on it. (JC) Jim, seeing how you and I are going to be very similar in arch design, did you feel the same or did you fly through that part? Well, I have poured over the domes built and have come to feel that Les's full bricks with tapered corners on them was the look I wish to do. I like Ken's dome look, but the full brick inside by Les really got my vote. The oven may end up looking only ok, functioning ok, but I am doing my best.
