It's time to go Vertical
  • Pompeii Nate
    • May 2011
    • 219
    #286
    Re: It's time to go Vertical
    RC,
    Your build is awesome and the info I have found reading through your thread is priceless.
    Fantastic job!
    Nate
    http://www.fornobravo.com/forum/f8/p...two-21068.html
    • videts38
      • Apr 2012
      • 107
      #287
      Hello JCG,
      I'm currenly in the process of planning my 42" WFO build and have been doing ALOT of reading on this forum site. Trying to ease from the planning to building process as smoothly as possible. And by the way I'm a novice to masonry and not an engineer.
      I have been reading about your angle cuts on the firebricks. I have 3"x4.5"x9" bricks and wanted to try figure out the angle cuts for this projects. You mentioned you might put together a spreed sheet for the calculations of the angles by plugging in the brick info. I was wondering if you ever did this and if possible can you forward me a copy of the spreedsheet to use in my build. I wasn't sure if the chart you have attached would apply to the size bricks I have.
      I'm trying to figure everything out before i get started to ease the stress (LOL) I'm geting before I even start. thanks and I look forward to your reply.
      Steven
