dusty's Door
  • dusty
    • Oct 2007
    • 575
    dusty's Door
    Well...I think that's it for my door. Steel front, FB board in the middle, with a 1/2 inch piece of ceramic "hardybacker" board in back next to the fire. I bolted it together with carriage bolts and bolted a gate sping on there for a handle. Fits like a glove. Now for the test. I'm not possitive about the backer board, but I think it will work just fine. Gotta be better than stackin' and unstackin' those red hot bricks!
    dusty
  • james
    Brick Oven Merchant
    • Mar 2005
    • 4648
    Re: dusty's Door
    Dusty,
    Nice looking door. I think you should think about a way of sealing the board on its edge. It is an industrial insulating product, and you should keep it sealed to lock in the fibers.
    • dusty
      • Oct 2007
      • 575
      Re: dusty's Door
      Originally posted by james
      Dusty,
      Thanks. You are probably right. Thought about that some, but not alot. I was hoping that the steel or the backer board would take most of the big hits. Will the heat cause it to deteriorate?
      dusty
      • james
        Brick Oven Merchant
        • Mar 2005
        • 4648
        Re: dusty's Door
        Dusty,
        It isn't the heat, but the fibers being in the air where you will breath them and they will come in contact with food.
        • Ken524
          • May 2007
          • 1655
          Re: dusty's Door
          Perfect! It's simple and should work great.
          Nice job.
          Ken H. - Kentucky
          42" Pompeii
          • dusty
            • Oct 2007
            • 575
            Re: dusty's Door
            Dusty,
            Oh...I got ya. Could I coat it with something that wouldn't catch on fire?
            Like furnace caulk? Or sould I encase it?
            dusty
            • telehort
              • Jan 2007
              • 193
              Re: dusty's Door
              cool looking door dusty. I was wondering the same thing about seeing if you could encase the edge by spreading some furnace cement or something like that on it. I wonder if that would spread on, but then would be "brittle" when dried.
              • gjbingham
                • Sep 2007
                • 2021
                Re: dusty's Door
                Dusty,
                I think James is possibly referring to the possible carcinogenic or other ill effects of breathing/eating the fibers.
                Love your door! Something around the exterior to keep the ceramic fibers in there - I've yet to do that to mine.
                GJBingham
                • asudavew
                  • Jul 2007
                  • 1880
                  Re: dusty's Door
                  Nice door Dustman.
                  How heavy is the sucker?
                  They make an aluminum tape.... for furnaces etc. I think it would be perfect to run around the edges. It would require replacement from time to time... but it is thin and wouldn't make your door any bigger.
                  I will see if I can find some online. I usually buy it at Lowe's when I need it though.
                  Dave
                  My thread:
                  My costs:
                  My pics:
                  • asudavew
                    • Jul 2007
                    • 1880
                    Re: dusty's Door
                    Best example I could find.
                    12 roll Aluminum Foil Tape Duct work Insulation repair - eBay (item 350036353926 end time Mar-20-08 10:10:03 PDT)
                    But it shouldn't detract from the look of the door.
                    My thread:
                    My costs:
                    My pics:
                    • vincent
                      • Jun 2006
                      • 66
                      Re: dusty's Door
                      the tape should be available at any decent hardware store..its quite sticky but is prone to tearing easily..i always keep a roll in my work van..mabey it would be better if you could find a tin knocker that could roll the edges of a thin piece of aluminum over and then wrap the exposed edges slipping the front edge behind the metal if the space allows
                      • james
                        Brick Oven Merchant
                        • Mar 2005
                        • 4648
                        Re: dusty's Door
                        Originally posted by vincent
                        maybe it would be better if you could find a tin knocker that could roll the edges of a thin piece of aluminum over and then wrap the exposed edges slipping the front edge behind the metal if the space allows
                        That's a good idea. Could you use cheap aluminum flashing from Home Depot?
                        • Ken524
                          • May 2007
                          • 1655
                          Re: dusty's Door
                          Just this morning, I was thinking about this and came up with the aluminum flashing idea as well. I have a roll in my garage and will try it on my door in the next few weeks when monsoon season is over.
                          Ken H. - Kentucky
                          42" Pompeii
                          • thebadger
                            • Jun 2007
                            • 383
                            Re: dusty's Door
                            Ken,
                            I second that - it's been raining in Cincy for 2 days straight and there's a lot of flooding going around. I guess I'll have to put off my hearth pour (too cold) this weekend.
                            Dick
                            • dusty
                              • Oct 2007
                              • 575
                              Re: dusty's Door
                              Originally posted by asudavew
                              Nice door Dustman.
                              Dave
                              What's crackin' my texican brother? Long time. Good to hear from you... and a most excellent call on the tape. I know that stuff. They used it on my commercial refrigerater at work. That is precisely what I will start off doing. If that doesn't work, I'll go to the NEXT easiest thing. Thanks for doing the e-bay research, but I'm sure I can find it at the local "mom and pop's heating and air" joint. I like to shop at those places.
                              How's everything? Family good?
                              Be sure to tell them all that your pal-from-Cal was asking about them and get that videographer daughter of yours off her butt...I'm ready for for more lessons!
                              Got plans for pizza night #4 on Friday. Wish you and wife and kids could come. I will have the door taped up properly and will post a complete report.
                              dusty
