dusty's Door
Re: dusty's Door
If you guys started the tape before the door plate (or unbolted it to tape it Dusty) you could hide the tape on the door side and back so it would not detract from the door when in place. Designing the plate slightly larger that the insulation and backing (just more than the thickness of the tape
) might also serve to protect it as it was put in and out.
...just thinking. I'm going to have to make an insulated door now.sigpicTiempo para guzarlos.....
...enjoy every sandwich!Comment
Re: dusty's Door
Nahh... no asking necessary. I posted it so it could be copied (or better yet, improved upon).
Yep. Spring is just about here. I was able to get out to the workshop and start cleaning up the messes created over the winter. I hope to be back to work on the oven really soon. Possibly tomorrow afternoon!Everything going OK over there in KY?
Keep up the good work on your oven!Ken H. - Kentucky
42" Pompeii
Cost Spreadsheet ... Picasa Web AlbumComment
Re: dusty's Door
Good call. I will unbolt it, tuck the tape in behind the steel and the backer board, and re bolt it together. I think I will weld a piece of steel across the bottom as the tape will surely wear out from sliding across the brick floor.If you guys started the tape before the door plate (or unbolted it to tape it Dusty) you could hide the tape on the door side and back so it would not detract from the door when in place. Designing the plate slightly larger that the insulation and backing (just more than the thickness of the tape
dustyComment
Re: dusty's Door
That should work great. I plan to start with the tape 'cause it's easy and I'm into easy.
I'll keep you posted.
dustyComment
