39 inch Corner Build
    • 5263
    #136
    My rope was fairly flexible/compressible as I stuffed it in conformed to the gap. So my round rope became elliptical to fill the gap. I would think 3/8" or maybe 1/2" would be fine. I think my gap was about 1/2" and I used 3/4" or 1" braided rope. 61A Ceramic Rope 8.25.12.JPG
    • JRPizza
      • Jan 2012
      • 1557
      #137
      Thanks! I'll probably cut the chamfer on my bricks and mortar up the arch before I buy, as I am sure whatever gap I shoot for will end up slightly different
      Is some sort of a spacer recommended to achieve a consistent gap?
      My build thread
        • 5263
        #138
        I did not use any type of spacer, just but cut all the bricks the same. Once stuffed with rope and sealed the final outside coating hides all never to be seen again.
        • RandyJ
          • May 2010
          • 1191
          #139
          It really depends on the road you get. The stuff I had for the Arch was called 1\4" but was fluffy and was more like 3\8" the one I used for the floor was denser and was labeled as 5\16" and went in to my gap nicely. I think it was roughly 1\4" gap both places.
          Randy
          • RandyJ
            • May 2010
            • 1191
            #140
            I used the heavy card board from my insulation board box as it was roughly 1\4" thick with some wax paper to keep it from sticking.
            Randy
            • RandyJ
              • May 2010
              • 1191
              #141
              Randy
              • JRPizza
                • Jan 2012
                • 1557
                #142
                Sounds good - probably what I'll do. It'll help keep the inner arch clean too, as I am not very good at keeping the mortar where I want it.
                My build thread
                • DavidApp
                  • Sep 2012
                  • 348
                  #143
                  Hello JR
                  Thank you for the comments on my finish. I was looking for something different from stucco and knew that my stucco skills sucked.
                  I used 2 lengths of 3/8" rope in the air gap and the bricks compress it a bit, In the vertical sections of the air gap I stuffed Fiber Blanket in the gap.I overlapped the arch section of the vent with the inner arch and left a 1/4" to 3/8" gap in the vertical section.
                  I have seen another build using a similar arrangement for the entry into the chimney. Not sure where.
                  David
                  • JRPizza
                    • Jan 2012
                    • 1557
                    #144
                    David, I thought about doing the overlap like you did, with notched bricks, but was not sure what the advantage would be. My "thin" arch bricks will be about 3 3/8 thick/deep, so I don't think I need to overlap them on top of the inner arch for stability. What was your thinking when you went that way, if you don't mind asking?
                    My build thread
                    • DavidApp
                      • Sep 2012
                      • 348
                      #145
                      Hello JR
                      I was concerned about smoke escaping through the gap and I thought that it may add a bit of strength to the arch as the bricks were wider. Easier to add the sealing rope between the inner arch and the overlap.
                      David
                      • JRPizza
                        • Jan 2012
                        • 1557
                        #146
                        All good points. How thick would your arch bricks have been without the overlap?
                        My build thread
                        • DavidApp
                          • Sep 2012
                          • 348
                          #147
                          Not sure. I will check in the morning.
                          • JRPizza
                            • Jan 2012
                            • 1557
                            #148
                            Thanks - also, did you lay the rope down then build the arch over it, or stuff it in gap when you were done? It seems like with post stuffing there is a good chance of snagging the gasket trying to insert it.
                            My build thread
                            • DavidApp
                              • Sep 2012
                              • 348
                              #149
                              Hello JR
                              I laid 2 pieces of rope across the arch then built my vent arch on top of the rope being careful not to compress the rope too much.
                              The arch closest to the inner arch would have been 2 1/2" thick if I did not have the overlap.
                              The photo is of one of the bricks that I had to scrap as it was too thin to make the arch radius.
                              David
                              • JRPizza
                                • Jan 2012
                                • 1557
                                #150
                                Gulf suggested I try an overlap too back in an earlier post but I was thinking I would put in a bevel like UtahBeehiver did in his killer build and RandyJ showed in his post #91, but I was not accounting for my planned 1.5 inch reveal and 4.5 inch tall arch bricks, which makes the vent arch 1.5 inches taller than the inner arch. I believe the top of their arches were at the same height. With the mis-matched heights, a bevel sufficient to provide a space for a gasket would take out quite a bit of brick (pic 1). I think this limits my heat break options to either cutting a notch (pic 2) or overlapping (pic 3). I think the overlap has a two advantages over the notch design - arch and chimney stability (a little more brick and mortar, and less chance of insulation falling off gasket if placed in the horizontal gap). I would probably forego putting any insulation in the vertical gap - does not seem necessary and without a notch to trap it more chance of fibers falling into the working area.
                                My build thread
