Russell, I have a partial bag of briquettes from before I got my gas grill that I might use, but with all the tall evergreens dropping branches this winter in my yard I have way more small fuel than I am going to need. I was able to keep the temps low - I think I might have spiked into the 350 range briefly, but my dome is pretty dry as I finished it last fall and kept the rain off it. Most of my moisture is in the floor bricks and CF board. I'm still going to go low and slow.
Larry, I am curing without chimney. I could put it on, but would need to remove it if the rains came. I pulled back the temp tarp over my structure, mainly because I could and the forecast is dry for the next few days, but the heat was low for the first fire. I have one more row of bricks to "cap" off the chimney bricks, then I need to work on building up my roof structure. I am struggling to figure out what kind of roof, how to flash the pipe, and how to make it as minimalist as possible but still be able to get up on it if needed to fix a leak or even to drive fasteners. Also need to work on my permanent door, and maybe a heat resistant temporary to use during curing, as it will take me a little time to make the good door and I don't want that to be a pacing item. Sorry to hear you are expecting rain - we are having a mini-heat wave and may hit 80 in Seattle today!
but yeah I think I don't need to worry about draw too much, and also don't care about smoke-staining the ebony bricks on my outer arch either.
