Hello,
I finally got my outdoor kitchen concrete pads poured today, and getting ready to build my oven!
I poured a 77x86 foundation per the plans I found on the forno bravo site. What I am confused on is for a dry stack how can you come up with the dimensions of
69″ x 76″ when using 16" and 8" block (regardless if you use the 8", 16", or the actual dimensions of 5/8 less). I would assume this means you need to cut the block, but wondering if there is a easier way? Also, if you cut a block, its going to throw off the cores from lining up (I believe), which would make it hard to pour every other core full with a rerod all the way down?
thanks!
Yeager
thanks!
Yeager
