Yeager,
I did polished concrete with embedded glass. You start with 50 grit diamond pads and progressively work up to 400 grit. I would be cautious using a regular orbital sander with water without some type for GFI protection. I used a Hardin wet polisher that was variable speed (essential) that had GFI protection as part of the cord. There is a YouTube video by Cheng that gives you a good understanding of the concrete counter polishing process. The process takes several days and like curing you have to be patient for the best results.
