36" Midwestern Pompeii
  • Saluki
    • Aug 2011
    • 89
    Slab was poured last Fall, oven construction has now began, hopefully finish by this Fall.
  • Saluki
    • Aug 2011
    • 89
    • Saluki
      • Aug 2011
      • 89
      • Saluki
        • Aug 2011
        • 89
        • Saluki
          • Aug 2011
          • 89
          I made the base layer from split upon the recommendation of someone on the forums to avoid a seam where the floor meets the wall. Not sure if it will matter but figured I would give it a whirl
          • Larry P
            • Aug 2014
            • 149
            I like the idea. I heard of people having problems with their peel getting wedged in that gap. I put a think layer of 50/50 sand & fireclay under the floor, which raised the floor about 1/8 inch and provided the same protection you have. But, your idea is a little simpler.
            Make sure you have a gap between the floor and the wall. The floor will expand faster than the wall when burning, and you need some give there to prevent it from cracking the walls. A strip of corrugated cardboard should be wide enough.
            • RandyJ
              • May 2010
              • 1191
              Yes make sure that you have the expansion gap. It is very necessary. I had heard the same thing about getting the peel stuck but I think it might just be a rumor. I have never hit the back of the oven so I don't see getting it stuck. But I did a half solider course to prevent it.
              Randy
              • Saluki
                • Aug 2011
                • 89
                Thanks. I did leave a gap, based on recommendations found here, Been lurking for a while, the dome is steadily going up.
                • Saluki
                  • Aug 2011
                  • 89
                  • Saluki
                    • Aug 2011
                    • 89
                    • RandyJ
                      • May 2010
                      • 1191
                      Wow looks like you are making a lot of progress. Keep up the good work.
                      Randy
                      • Saluki
                        • Aug 2011
                        • 89
                        Here is the jig I made up, I don't think I needed it based on the saw but it made things go much quicker.
                        • Saluki
                          • Aug 2011
                          • 89
                          • JRPizza
                            • Jan 2012
                            • 1557
                            Build is looking good. What kind of mortar are you using? The color is quite a bit different than the homebrew I used.
                            My build thread
                            • Saluki
                              • Aug 2011
                              • 89
                              It's the Heatstop50. First batch was a bit of a learning curve, went with smaller batches after that and seems to be laying out pretty well. Price adds up in a hurry thou.
