36" Midwestern Pompeii
  • Saluki
    • Aug 2011
    • 89
    #61
    • Saluki
      • Aug 2011
      • 89
      #62
      • Saluki
        • Aug 2011
        • 89
        #63
        • Saluki
          • Aug 2011
          • 89
          #64
          • Saluki
            • Aug 2011
            • 89
            #65
            • Saluki
              • Aug 2011
              • 89
              #66
              For those that have completed a doghouse style oven - Would you recommend 3" of ceramic blanket or 2" blanket and loose fill with vermiculite? I plan to start wrapping this baby and building an enclosure soon and just wanting some input from those that have been down this road?
              Thanks in advance.
              • Saluki
                • Aug 2011
                • 89
                #67
                For anyone interested. It took 200 bricks nearly exactly to build the dome/vent/landing. Standard size firebricks.
                • Saluki
                  • Aug 2011
                  • 89
                  #68
                  And another question - If I go with the vermiculite - Should I loose fill or go with a vermicrete blend and cover the blanket within the enclosure?
                  • Saluki
                    • Aug 2011
                    • 89
                    #69
                    Got the anchor plate mounted today.
                    • Saluki
                      • Aug 2011
                      • 89
                      #70
                      Well, I guess insulation is next, likely early next week. I have tow boxes of this, I'll see how far it gets me and decide from there whether to get more blanket or fill with loose vermiculite.
                        Two 50 square feet boxes should do you just fine.
                        • Saluki
                          • Aug 2011
                          • 89
                          #72
                          Thanks for the response Gulf - I got it covered with 3 complete layers, almost 4.
                          • Saluki
                            • Aug 2011
                            • 89
                            #73
                            This was my first attempt with steel studs, they are pretty nice to work with, although a bit weak until you get them covered. This was my first attempt to frame the walls and ceiling.
                            • Saluki
                              • Aug 2011
                              • 89
                              #74
                              Wife thought the slant roof would look like a big commode in the back yard, so that was torn down for a gable roof.
                              • Saluki
                                • Aug 2011
                                • 89
                                #75
                                This is getting closer.
