Just answered one of my questions: the wet tile saw is too small (not enough clearance on the moving bed to the engine housing) to cut through a brick. Takes 4 cuts to score it enough to snap a brick in half. Not ideal for precision bevelling.
So... can I cut them dry?
). Since you've got another builder nearby, you might see if you can pick-up a wet saw from Harbor Freight and split the cost & use. Also, if you have any builder friends or contacts it would be worth checking with them. I borrowed a 12" wet saw from a retired contractor down the road with the promise of delivered fresh bread...after 7 years, I still deliver them a "thank you" loaf every week I bake.
I'm going to just start the dome and carry on then. No special treatment of the first course.
