Currently planning an 18" entry width that is just over 10" tall. Chimney will be 6" ID. Is this adequate for a 32" (workability vs heat loss)?
I plan to cast over sand the dome up to what would be the inner arch in a brick oven. The entry will (from a side view) be a vertical face of the above size. Then I plan to caste the gallery/flue as a 2nd piece, in place with some cardboard between them to form my thermal break.
For the gallery, I will try to funnel up a flue to a 10"x10" anchor plate. I noticed on other cast builds, the chimney flue is actually pushed back into the dome area somewhat. Is this for performance, or to just save on size/weight? These were for mobile builds such as David's or the one here at a local restaurant, but I am hoping to keep the gallery relatively short. Should I be trying to move the flue back into the dome area more?
Lastly, what sort of setback from the edge of the Hearth to the front of the oven gallery is typical? I have plenty of room on my hearth, but moving it back, gives me more counter space on each side. Moving it forward makes it easier to access...
