I am very excited to have started my project which consists of a masonry fireplace, built in grill top, refrigerator, and a pompeii dome. this has been long in the making. I have read many good posts on this forum and I can only hope to achieve the results as all of you have had with your builds.
36" Pompeii Dome Chicago
Tags: None
Oh my, such a massive fireplace
lol argentinian grill not to small itself. looks good!My Build Pictures
Just finished the outdoor kitchen and fireplace and this spring i will tackle the pizza oven. i have pictures in my shared folderMy Build Pictures
Getting ready to start gathering materials for the homemade mortar...Ordering my insulation from distribution international consisting of 1" foamglas, and 2" thermal gold 12. Firebricks are very easy to get here and always in stock. Just have to figure out how I want my enclosure to look. I was thinking of a arched roof I have seen one made in here but not sure. I have a rough sketch of my oven and my inner arch opening just curious if anyone sees anything out of the ordinary. im doing a flared vent landing but not sure what the disadvantages are in it. Im going to take david s advice and make the flue an inverted funnel design as well. Im interested in any input. I also included the picture of an oven I saw with the roof i was thinking about doing. * Update I Just was browing the forum and was reading a coffee roasting thread and I found the owner of the oven's roof I Liked. It belongs to fornax hominus Nice job makes the enclosure look a lot different than a typical dog house roof.3 PhotosLast edited by Chach; 03-03-2019, 08:33 AM.My Build Pictures
Just looked at your photo album, nice rock work. Oven door is the correct ratio height for a 36" ID oven. Flare entries are nice but they do add an additional complex angle to deal with where the vertical walls and arch meet but not a deal killer, just need to be aware of it. What part of Chicago, the Big Boss is from the NW burbs.
I used to live near downtown but moved to the SW burbs around 15 years ago. I frequent the NW burbs a lot for work. Thanks for the compliments the stone work was a PITA simce I went jointless...if i did a mortar joint it for sure would jave sped up the process. I did a joint on my inside fireplace amd I flew through it. I will say going jointless looks great but tons of added time to the build. I did the cinder block structure and slab pretty quick but that stone work easily doubles in time. I really like your attention to detail and your copper panels are truly a work of art. Nice Job I know you hear that all the time but it mever gets old. lolOriginally posted by UtahBeehiver View PostJust looked at your photo album, nice rock work. Oven door is the correct ratio height for a 36" ID oven. Flare entries are nice but they do add an additional complex angle to deal with where the vertical walls and arch meet but not a deal killer, just need to be aware of it. What part of Chicago, the Big Boss is from the NW burbs.My Build Pictures
So I have some mixed information and I'm looking for opinions and answers. if i go with an outer arch with straight sides and a small curve at the top instead of a semicircle im probably going to have to buttress the sides. The question is does that butressing need to be on insulation or can it sit right on the concrete. Im assuming I would want the bottom brick from the butressing to be mortared down do.its more secure and stable bit will the oven wick heat out if i do that or not that much since its outside at the end of the vent landing.
RickyMy Build Pictures
Not sure but I built my hemispherical arch with the bricks on insulation, it is the only part of my oven that I am worried about the long term durability. If there are any dilation forces from heating/cooling cycles there may be a tendency for the arch to want to spread, since it is supporting a pretty good load. If I had it to to over again I would probably have put the entry bricks on insulation and the arch bricks on concrete.
Just my thoughts.My build thread
Ricky, I put my outer arch bricks and buttressing on concrete blocks (no insulation). I haven't had any issues with them and have not noticed excessive heating in that outer landing area. There are many builds that have placed a small expansion gap that separates the heated oven area from the chimney/outside arch section. With the expansion gap (filled with either ceramic batting, fireplace gasket rope, or high temp silicone seal), you seriously reduce problems from potential cracking/movement caused by the dome expansion during firing. Although I did not add this gap, I have not experienced any problems with my oven and my heat retention is plenty adequate for us.
It sounds like you are going to do an outer arch as I did (straight sides, slight top arch). In my thread (link with my signature lines), posts 8-10 show the perlcrete insulation base of the oven. Later in the thread you'll see how I buttressed the outer arch/flue chamber without being on the insulation pad.
Hope that helps...
Roseburg, Oregon
I was thinking the same thing and I don't think Id have much heat loss from the arch being on the concrete. ThanksOriginally posted by JRPizza View PostNot sure but I built my hemispherical arch with the bricks on insulation, it is the only part of my oven that I am worried about the long term durability. If there are any dilation forces from heating/cooling cycles there may be a tendency for the arch to want to spread, since it is supporting a pretty good load. If I had it to to over again I would probably have put the entry bricks on insulation and the arch bricks on concrete.
Just my thoughts.My Build Pictures
Thanks Mike I appreciate the info I was thinking of doing what you did....I'll review your build againOriginally posted by JRPizza View PostNot sure but I built my hemispherical arch with the bricks on insulation, it is the only part of my oven that I am worried about the long term durability. If there are any dilation forces from heating/cooling cycles there may be a tendency for the arch to want to spread, since it is supporting a pretty good load. If I had it to to over again I would probably have put the entry bricks on insulation and the arch bricks on concrete.
Just my thoughts.
My Build Pictures
Well Sunday it snowed over 4" and the next day snow was gone..This weather is toying with my emotions. So today I started my oven floor and got that all laid out and put down the insulation 1 1/2" foamglas ans 2" thermogold 12. oven floor brucks are on top, laid out and ready to cut. rain is coming so I had a tarp the build right now but now I feel like I'm finally on my way once I cut the brick I may pick it up again and throw some fireclay down and sand and level out the bricks a little better. Next is to construct my indispensable tool and start this bad boy2 PhotosMy Build Pictures
Quick question...I leveled my cooking floor using sand and fire clay mix. Now that the floor is level and when i start the actual dome do I use fire clay sand mix to level the dome walls first course or should I use refractory mortar (home brew) to level the first course of the dome.My Build Pictures
