42" build in McPherson KS
    Seth,
    Great looking bird! I admire y'all that cook turkeys with open coals. I've been a little skeered to try it, though I have done chicken that way. Actually, I don't do turkey. But, I love seeing those cooks that do. I'm going to have to break down and try it some time
    .....My wife thought it was strange that we never even turned on the conventional oven once for our Thanksgiving meal......
    These ovens are great at taking a load off the power bill and also helping the ac to keep up. We've used ours when there was no power on the grid!
  • slschoming
    Wood fired Thanksgiving! My wife thought it was strange that we never even turned on the conventional oven once for our Thanksgiving meal. Though we did use the stove top for potatoes and gravy.
  • slschoming
    Had great weather this weekend, stayed above 42 overnight Saturday so I was able to get my last coat of stucco on and started to turn the corner on my chimney bricks... And of course we had more pizza..
  • slschoming
    Originally posted by mintee
    Looking awesome! Quick question, are you not concerned about the firebrick being exposed to the elements during the winter? Like, it it rains, and the fire brick drinks up all the water, then freezes, couldn't it crack a brick? (Sorry to instill fear)
    Yeah, I think I will drape some plastic over the front face this winter, and hopefully before next winter I will have my roof built
  • mintee
  • slschoming
    Made about 30 pies yesterday evening. My wife made scones this morning and I've got some bread going right now. It's incredible what you can do with just one fire.
    It's also pretty awesome that while the inside of the oven walls are over 1000 F, the outside stucco layer is cool to the touch.
  • slschoming
    The temperature is changing and the leaves are falling. I was hoping to find a day warm enough to finish the stucco but it's not looking promising.
  • slschoming
    I just checked the weather and it's looking like my nice days are coming to a close for a few months. Are there any issues with waiting 3-5 months between the brown and finish layers? Our lows are in the 40s now, but starting Thursday it looks like they will be consistently in the 30s and below.
  • slschoming
    Originally posted by david s
    To save time, instead of doing the recommended 3 costs, I only do one coat of around 15 mm thickness with the added AR fibres, and sponge finish this layer. Cover for a week to hold the moisture in this layer. Then, after several firings (if moisture is still present it can cause blistering) I then use a thinned 100% acrylic render which can be painted on. This smooths out any tooling marks and creates a waterproof finish.
    There are lots of different approaches so don’t have to follow my method.
    I've done two layers with no fibers added already. It is wet and covered, but the wind was so strong while I was applying it that it was drying out quickly. It developed a couple hairline cracks before I rehydrated and tarped it. At this point I think my best bet it to incorporate fibers into my finish coat. It doesn't have to be pretty, I am only going for structure and waterproofing with the stucco layer, I will be adding a brick veneer around the whole dome and applying a brick seal when the last layer of stucco dries.
    To save time, instead of doing the recommended 3 coats, I only do one coat of around 15 mm thickness with the added AR fibres, and sponge finish this layer. Cover for a week to hold the moisture in this layer. Then, after several firings (if moisture is still present it can cause blistering) I then use a thinned 100% acrylic render which can be painted on. This smooths out any tooling marks and creates a waterproof finish.
  • slschoming
    Originally posted by Gulf
    The fibers a not very big. If you have an old window screen, sieve a hand full through it.
    I don't have a screen to try this with, but I am fairly sure it doesn't have any... Quikrete has a base coat that is reinforced with fibers, and one that is not. I couldn't find the fiber reinforced variety in any nearby stores so I went with the plain old stucco mix.
    https://www.quikrete.com/productline...reinforced.asp vs https://www.quikrete.com/productline...wnbasecoat.asp
    I think I better go with the Quikwall for my finish layer to be safe.
  • slschoming
    No, the premix should have fibers in it that add a lot of strength. But, do complete all 3 coats.
    The premix that I bought (QUIKRETE Scratch and Brown Base Coat Stucco) doesn't seem to have any fibers. Neither does the finish coat. However, I bought some QUIKWALL Surface Bonding Cement last year that I was sort of thinking to put on my cinderblock walls. Quikwall has fibers and they say it can be used as a finish coat. Lowe's website says that it is used to waterproof farm water storage tanks as well.
    Maybe I should use this as my finish coat instead for the fibers and extra waterproofing?
  • slschoming
    Ok, will do! Thanks Gulf!
    ....Do you think I should wrap this coat in the hardware cloth.......?
