The arrow in the pic above is pointing to the inner arch that is integral with the dome. The outer arches are part of the vent/landing and are typically larger in height/radius (1-1.5 inch) so that the exposed part of the inner arch acts as a reveal for the door to seal up against.
I didn't see where/when you figured how big of an oven you were going to build - you are going for a 41"? Just curious how you came up with that number. I picked 39 as if I went an larger I would have needed to buy 2 more insulating boards, and I didn't want to go down to a 36".
For a 41 inch oven, I would make the inner arch height probably larger than 12", as that works out to be around 58.5% of the dome height where I believe the ideal is around 63%. 12.75" would put you at close to 62%. Building the vent arches is one of the less well documented parts of a build on the forum but lots of the recent builds have done a better job of describing how to do it. My build has some good pics if you have not taken a look yet.
