Yes, I think that is a better solution. Regarding the stucco supporting the flue pipe, it is also a problem area for cracks and water entry. A solution that works pretty well is to wrap some box cardboard around the pipe that you can stucco up to. When the stucco has set hard remove the cardboard and fill the gap with high temperature silicon. This deals with the pipe expansion wanting to crack the surrounding stucco and provided the seal is maintained, prevents water running down the pipe from entering into the insulation layers. Just be careful, crazy flames up the flue (like my wife did one day when firing up) will kill the high temp silicon, but not too hard to redo.
42” Pompeii in San Felipe, MX
david s thanks!!! I like the cardboard idea. Excellent idea!My Oven Build
https://community.fornobravo.com/for...mx?view=thread
Time to break out the premium tequila. I hope I never have to cut another firebrick again. Feels good to be done with this phase. I’m paying the locals to do the stucco. LOL. My back cant take anymore. What a pain in the butt that last bit was.
I went through so much trouble to make the anchor plate level, and it was... but the part of the pipe that twist snaps in is not true to the plate from the manufacturer. It’s only out 1/4 of a bubble side to side and the stucco buy will fix that. Overall I’m very pleased with the job so far. I’ve learned that I’d never make it as a mason.
Tomorrow I will install the ceramic rope gasket and seal the little gap at the reveal. I need to search curing fires. I’ve seen some that insulate before the fires and some that don’t or didn’t. I want to do some small fires that are pretty smoky to make sure my gasket and sealant will at least keep the smoke back. I get that once flames wick up at that heat break will be a game changer, but if there is anything blatantly wrong I wanna fix it before I put this thing under a blanket
Thanks everyone for all the help along the way,
Mikie V.4 PhotosMy Oven Build
Looks good - nice clean joints!My build thread
I am a big proponent of having insulation of the dome before you fire. This reduces the heat differential between the inside of the dome and outside of the dome temps, reducing expansion and crack potentials. But don't stucco until the curing fires are done.You also may want to consider some type of vent at the apex of the dome so any water vapor and release out.
OK... thanks guys. I will start the insulation process tomorrow after I get the heat break sealed up. I can do a vent thing no problem.
I do have a question: So, I’ve got almost a full bag of fire clay, portland, lime and sand left over. Is there any benefit to just mix it up and coat the dome and arch with it? This stuff will just get funky in the garage here once the humidity rises. Is it worth the effort?
You guys are the best. Thanks,
Mikie V.
My Oven Build
That would give you more thermal mass but possibly longer heat up time and more fuel usage. You did a great job and I was glad you ended up taking those bricks off an redoing your flue gallery because now you don't have the what if factor on your build.
RickyLast edited by Chach; 04-21-2020, 07:14 PM.My Build Pictures
Thanks Ricky... wood is expensive here... good point. I didn’t think about that. I will gladly gift the lime. I will put the fireclay in my horseshoe pits. The sand and portland will get used up I’m certain. Thanks man.My Oven Build
- Likes 1
So I swear that there was a “Must See” video in regards to putting down the FB insulation blanket. I can’t find it. Anyone able to point me to it? Is it really necessary?My Oven Build
That was very informational. Thanks.My Oven Build
B Valiant thanks. Yes, I did do the 63% thing. Dome height is 21” on the inside. Second layer of insulating blanket goes on today.
Thanks for checking it out, Mikie V.My Oven Build
Insulation done, need to finish the lath... took it too 350 and kept it there... slow cool down. Gonna fire it up again tomorrow.
Man, what a feeling!!!! Nothing like it. Just a few whispes of smoke out the front (lotta wind)... Seemed like the smoke just wanted to go up into the chamber. I’m very happy.1 PhotoMy Oven Build
Congrats! I remember the feeling - I have a shot of my first fire as my windows background
My build thread
