Heat loss through oven opening
  • Heat loss through oven opening
    I just completed my Pompeii oven - 46" diameter, 23" center height (+/-), 20.5" wide opening, 12.75" arched opening height (metal), 6" x 10" chimney vent at top of brick arch, 12" landing
    So, when starting fire, I get a fair amount of smoke out of the opening and every time I add new logs to fire. I followed design dimensions pretty accurately, so I'm not sure if this is normal or do I need to modify something.
    I have a rain protective cap on top of 4" vent pipe. A neighbor suggested a cap that allows better airflow across the top of vent to draw smoke and possibly a flue valvle to control draw.
    I would really appreciated any insights, anyone can provide. It's a tad frustrating to have smoke and heat out of the opening instead of up the vent stack. Thanks very much
    David
    A 4" vent pipe is undersized for a 46" oven. The FB plans call for an 8" pipe for a 40" plus diameter oven. A 6x10 opening at the top of your arch is good but that 4" pipe is not going to draw enough air.
    You need an 8" pipe.
    - George
    https://community.fornobravo.com/for...mente-ca-build
      I’m with Mongo on this. My oven is 42” and I have 3’ of 8” pipe... check it out, I still get smoke out the front. There are a lot of variables. Wind is a biggie.
      My Oven Build
      https://community.fornobravo.com/for...mx?view=thread
        So, when starting fire, I get a fair amount of smoke out of the opening and every time I add new logs to fire. I followed design dimensions pretty accurately, so I'm not sure if this is normal or do I need to modify something, or get a 500 dollar loan here https://directloantransfer.com/500-dollar-loan/.
        David
        This is a usual problem with a newly assembled ovens
        give it some time, after 5-10 times it will have normal flow of smoke
