East London pizza oven and grill
As Mike mentioned, I start my moderate size stack right under the chimney vent doing a top down burn, when the chimney warms up and is drafting good I push the stack into the dome and cranker up! PS this is after the oven us cured.
Originally posted by JRPizza View PostI think that is fairly normal. One of my friends that had the first oven I ever saw used to say you could burn tires in the oven and as long as your food was below the smoke line you wouldn't taste it. Not something I am going to try
He even had two tuscan style grills, one with long enough legs so his meat could cook up in the smoke area for flavor (hopefully no tires)
Originally posted by SableSprings View PostNice video Neil! What you are seeing is a perfectly normal startup. The flue needs to have the "contained air" heated in order for it to rise and start pulling in a good draw. Old timers with wood fired stoves would often light a pine-cone or roll of newspaper and hold it at the base of the chimney to get the flow going. If it's cold outside and you have a tall flue/chimney, the cold air contained in the stack actually resists the warmer air below...just like a plug in the system. That's why if you have a taller chimney it takes a little longer to get the draw started and why the pine-cone/newspaper is almost essential to get things moving more quickly. As the flue heats up, the draw increases and the smoke is pretty much "immediately" pulled up & out.
Hope that explains it well enough. By the way, I have always loved how you can see the layering of air moving in low (cool & clear) and exiting high (warm/hot & initially smoky).
I know it's only a small fire but considering I only had a makeshift chimney that faces the roof of the pergola, i was happy with the amount of smoke that went up. Only the odd wispers of smoke came out the arch, obviously the bigger the fire the more smoke, but i won't be doing any bigger until i add the flue.
I agree about the smoke layer exiting. You can see in my video the way it curves upwards without being anywhere near the inner arch.
- Likes 1
Well if your thermo blocks look that snazzy, I can't wait to see the actual slate! :-)
Great job closing the dome!
- Likes 1
From the inside. Still needs cleaning.
Most builds only have about 1" around the inner arch for smoke to be directed to the vent/flue but are 9" long.
Mine has 5"*8" in most areas. I'm hoping the 6"*3" side channels along with the large area above will allow smoke to exit without coming out the front.
I wasn't originally happy with my brickwork, but after the first fire I think it looks good.
2 Photos
You're making great progress! That slate looks awesome.. can't wait to see it all buttoned up. :-)
