You are reading my mind JRPizza, we have been having rain all day today and I think for most of the beginning of the week, so it will be a good amount of planning for me.
Ok, so I have tried to read CAD pictures and definitely not my strong point, but from what I can understand the "inside" of your arch brick was in the neighborhood of 13.5" from center??
I am going for the tight inner joints that you have in your build, so from what I can see the bevel is the same direction on both sides of the brick, correct?
For the "out of round" when I set my IT at 21" it is a little bit away from holding the brick without having a (what I would consider) significant lip. And I know it isn't exact science but when I measure somewhat straight across ID I have 42.5 in some spots. I have done the "second" course (even though I think it is the first considering I "Stretchered" the first) and it is floor level, and started the 3rd (2nd in my eyes) maybe 8 bricks. I think we discussed earlier that you didn't use the spreadsheet, My IT is centered, but 1.38 above floor level, so I am wondering at what point I pull that back a bit? (will the spreadsheet help with that, I noticed that I mentions what course an adjustable IT should be set at.) That way I don't end up with a 22.38 high dome
I will keep playing with that first arch brick at the floor level to see what I can do, from what I can see is my landing is flared and that may be why it looks angled.
Thanks again @ JRpizza and UtahBeehiver, yes I figured avalanche danger would be high this weekend, have fun for me when you can!
