42" Pompeii Oven in Jamaica
Originally posted by UtahBeehiver View PostNo, vent will not see temps to cause any melting problems, it just extends though the stucco layer to the top of the fiber blanket. It is placed at the top of the oven due to steam rises so I am not sure vents at the base give you any benefit.My Build - 42" Pompei Oven
Okay all...I'm starting my squirrel tail chimney.
Based on the design, the side walls are made from laying leftover refractory brick (no problem), and I am going to have to cast several small slabs for the top roofing part to close the channel going up to the actual chimney (tricky). Don't want whatever I am casting to break in the future.
From my research, I would do this cast out of the same refractory mix I have been making, with the addition of polypropylene fibers and stainless steel needles (melt extract SS fibers)? I may be able to source the fibers but definitely not the needles. is there an alternative to that, or is it not needed?Last edited by wthwaites; 12-14-2020, 03:07 PM.My Build - 42" Pompei Oven
With mine, I managed to find some firebrick slabs, 390x260mm, which I used as the top of the chimney "roof" as it goes up over the dome. You can see what I mean if you look at my build photos. When I got to the top (highest point of the) dome, I set one of those slabs flat, and, before mortaring it in place, I carefully cut a round hole in that slab, only very slightly smaller than the stainless steel flue. The bottom of the stainless steel flue therefore rests on top of that slab. I then built up a short chimney using ordinary clay brick (4 courses high) which supports the steel flue pipe all round. This has turned out to be remarkably secure and holds the flue pipe securely, even with very high wind conditions. Have a look at my build drawings and photos and you'll see what I mean.
I think your castings should work well. If I did not have the large firebricks (the same type as I used for my oven floor) I would have had to come up with a different solution and casting a top cover in segments would have been my next option, I think. There's very little load on top, so I don't think much reinforcing is needed. Certainly, you don't want to reinforce with something that will contract and expand and crack the slabs. I think the better reinforcing would probably be some furnace blanket fibres, rather than steel, but I'm guessing - someone else may have a better idea.My 42" build: https://community.fornobravo.com/for...ld-new-zealand
Well I got polypropylene fibers today but can't find SS needles, nor any SS mesh wiring; so looks like I will be casting with just the fibres. I'm hoping that the slabs will be fine and wont break at any time now or in the future...My Build - 42" Pompei Oven
- Likes 1
Originally posted by wthwaites View PostWell I got polypropylene fibers today but can't find SS needles, nor any SS mesh wiring; so looks like I will be casting with just the fibres. I'm hoping that the slabs will be fine and wont break at any time now or in the future...My 42" build: https://community.fornobravo.com/for...ld-new-zealand
The polypropylene fibres will melt at 160C so are not suitable for reinforcing in this application. Once they have melted they leave behind a network of minute pipes that steam can pass through. This reduces the incidence of steam spalling provided heat up is taken slowly.
The recommended reinforcing for refractory is stainless steel needles, but their use is not mandatory. Their drawback is their expense and difficulty in handling when placing the castable.Last edited by david s; 12-15-2020, 08:18 PM.Kindled with zeal and fired with passion.
- Likes 1
So the fibers aren't needed?
I was able to find needles, but they weren't stainless steel and was only available in 55 lb buckets at $250 - way out of my price range! For the amount I would be casting (essentially a 2' x 4' x 3" triangular slab divided into three pieces), I also think that the purchase would be a waste.
I'm all ears for alternative solutions. I may be able to find stainless steel threaded rods. Will that suffice?My Build - 42" Pompei Oven
The reason melt extract fibres (stainless needles) are recommended is that being a very small diameter they present a much larger surface area than thicker stuff. This enables them to dissipate their heat more easily to the refractory that surrounds them, thus reducing expansion issues of the two different materials. In normal ambient conditions eg red in a concrete beam the rate of temperature change is slow enough for the two materials to be quite compatible. But when extreme heat is applied > 200C/hr, then problems are likely to occur. You could try using some AR fibreglass fibres in the castable, glass has a melting point of around 900C so is well above our temp range.I use them as well as the stainless needles.Last edited by david s; 12-15-2020, 09:12 PM.Kindled with zeal and fired with passion.
I got Fibreglass fibres, so I'll be moving ahead with casting the slabs with both that and the polypropylene fibres. That's the best I can do with what I can source. Lets hope for the best!My Build - 42" Pompei Oven
- Likes 1
Originally posted by david s View PostMake sure they are the AR alkaline resistant ones.Last edited by wthwaites; 12-16-2020, 08:14 PM.My Build - 42" Pompei Oven
Originally posted by wthwaites View PostI was told it was glass fibres for concrete; I will double check tomorrow. If they aren't, they can't be used?Kindled with zeal and fired with passion.
- Likes 1
