Les' Build
  • Les
    • Sep 2005
    • 2945
    #151
    Re: Les' Build
    Thanks David. The acrylic stucco has a dye. I tried to match the cream color in the brick. The color is French vanilla (my favorite flavor in my coffee). We were going to sponge the surface with grays and reds to match the brick. The wife liked it the way it was.... That's what it's going to be. I posted a pic of my proposed door a while back. It requires the use of the laser, so I have to wait for the shop to have bandwidth to get it built. Same thing applies to my vent cover.
    Les...
    • David Manchester
      • May 2008
      • 52
      #152
      Re: Les' Build
      I know what you mean..my wife liked the white dome too. Then when she wasn't home I went out and started the swirls When she came back I said..wow that looks good. Honestly though her reaction coulda went either way. This time it went mine, It does look good though. That's cool you have access to a laser, I'm going to try my hand at a plasma cutter at my uncle's shop. Never really worked too much with metal, sO we'll see how it turns out
      Keep ya posted
      Dave
      p.s. When I was out at my friends shop in Mass, I was invited into this guys shop. He forges a lot of his stuff. Really has some cool creations
      Salmon Studios: Metal Sculpture and Installations
      David and Cynthia Manchester
      • dbhansen
        • Jun 2007
        • 566
        #153
        Re: Les' Build
        Wowza! Looks fantastic, Les!
        Picasa web album
        Oven-building thread
        • Ken524
          • May 2007
          • 1655
          #154
          Re: Les' Build
          Yeah, I agree with Daren. Fantastic. The final product is gorgeous.
          Ken H. - Kentucky
          42" Pompeii
          • Les
            • Sep 2005
            • 2945
            #155
            Re: Les' Build
            Another task completed. Finished the cover on the flue. Since the shop where I work is slammed, I had to make this in my shop - it's totally set up to work with wood It's all stainless steel, cost came in around $26.00. Note to self, wash the brick...
            Les...
            • Frances
              • Aug 2007
              • 2186
              #156
              Re: Les' Build
              Very nice Les, and it fits in beautifully with the rest of the oven! That's what I would call deceptively simple.
              • staestc
                • Oct 2008
                • 256
                #157
                Re: Les' Build
                That's just gorgeous Les!
                All my shop is wood too. I can't imagine how you built it out of stainless, but it just looks great.
                Are you going to do any kind of spark arrestor?
                Travis
                TravisNTexas
                • exceloven
                  • Aug 2008
                  • 279
                  #158
                  Re: Les' Build
                  Les,
                  Great job on the cap, as usual. I was wondering what is the purpose of the cap. Is it necessary.
                  Thanks, Mark
                  • Les
                    • Sep 2005
                    • 2945
                    #159
                    Re: Les' Build
                    Thanks all!
                    Travis - I wasn't planning on installing a spark arrestor, everything around the oven is brick.
                    Mark - I think they are needed. When I was spraying off the dome, some over spray went inside the flue. It left a nice square soot pattern on the hearth bricks. Don't know how well this will prevent it, but I will find out shortly, the weather is going to turn bad.
                    Les...
                    • Ed_
                      • Apr 2008
                      • 139
                      #160
                      Re: Les' Build
                      Originally posted by Les
                      When I was spaying off the dome...
                      Normally I wouldn't point out typos, but that one is sort of amusing.
                      • Les
                        • Sep 2005
                        • 2945
                        #161
                        Re: Les' Build
                        You're right, and I was consistent.... It's corrected - Thanks!
                        Les...
                        • james
                          Brick Oven Merchant
                          • Mar 2005
                          • 4648
                          #162
                          Re: Les' Build
                          I like the cap. As Frances noted -- it fits perfectly with the rest of your kitchen. Simple, elegant, well-executed. Great!
                          • james
                            Brick Oven Merchant
                            • Mar 2005
                            • 4648
                            #163
                            Re: Les' Build
                            Les,
                            One more thing. Is your work surface light permanently fixed and hardwired? Or is it battery?
                            • Les
                              • Sep 2005
                              • 2945
                              #164
                              Re: Les' Build
                              Thanks James. The lights are permanently mounted and wired. And as I stated in a way earlier post – drilling through the porcelain is NO fun.
                              Les...
                              • Les
                                • Sep 2005
                                • 2945
                                #165
                                Re: Les' Build
                                Finished the trim - I'm done!!!!! I still need to fabricate the door - doesn't involve mortar and I am good with that. On to the cooking section
                                Les...
