Les' Build
  • dbhansen
    • Jun 2007
    • 566
    #181
    Re: Les' Build
    Nice door Les! I like the wire wrap on the handles. Where did you find those handles, by the way? I was looking for some like that and came up empty-handed.
    Picasa web album
    Oven-building thread
    • Les
      • Sep 2005
      • 2945
      #182
      Re: Les' Build
      Bill - I believe that FB's door is only 1/4 plate steel. If that is the case, I should be golden.
      Dusty - I saved some of my board for the door, but at the end I didn't want to slice the stuff. It was a nasty job cutting it for the hearth. I'm sure it would have been a more efficient way to go.
      DB - I made the handles. I just cut the aluminum 1 inch wide and formed it (I used a grinding wheel to get the radius). The wire wrap is 10 ga copper from home depot.
      Les...
      • Dino_Pizza
        • Feb 2008
        • 1036
        #183
        Re: Les' Build
        Really great door Les! The #10 copper wire wrapped handles have a real artistic touch. It's got color, texture, the door retains heat and looks good too. You've come up with lot's of neat stuff for us to consider. Thanks man.
        -Dino
        My Oven Costs Spreadsheet
        My Oven Thread
        • exceloven
          • Aug 2008
          • 279
          #184
          Re: Les' Build
          Les,
          Its nice hearing from you on your build thread. More inspiration! As always your door is very clean and tight. The handles make it, they are really cool. I'm anxious to hear how it performs. Although I think we know already.
          Mark
          • gjbingham
            • Sep 2007
            • 2021
            #185
            Re: Les' Build
            Les,
            Wonderful! Stunning! Congrats on finishing your masterpiece. Well worth spending the extra time to finese the dome and finish work. Job well done!
            I skipped a bunch of the thread in my attempt to catch up. What BBQ did you decide on to complete your island?
            G.
            GJBingham
            • bbell
              • Oct 2008
              • 195
              #186
              Re: Les' Build
              Les, You are a true artisan and now mentor. Thanks for sharing.
              Bill
              Bill
              Oven Build: https://goo.gl/photos/rN6FhFSS2jzwfQuB7
              Oven cooking: https://photos.app.goo.gl/1vmPg7XXSbMwhdnD6
              • Les
                • Sep 2005
                • 2945
                #187
                Re: Les' Build
                G.
                I went with the Jenn Air.
                • Les
                  • Sep 2005
                  • 2945
                  #188
                  Re: Les' Build
                  An update on the door.
                  After cooking pizza's ( Saturday night) I went out and put in the door. The hearth was 611 deg. The next morning it was at 464. I baked 2 batches of bread Sunday afternoon (in the snow) and the temp was down to 337. I checked it tonight (48 hours after the fire) and it's at 226. I would think that it's working well enough. I do feel warmth on the outside so it's far from perfect. Also, it's been pretty cold - 25 deg at 5:00 PM. I know some of you in the NE would consider that balmy - just shows you what cold can do to your brain
                  Les...
                  • gjbingham
                    • Sep 2007
                    • 2021
                    #189
                    Re: Les' Build
                    Sounds like great numbers to me Les. Mine goes from 800 to 400 in about an hour. One bread bake is all that I can muster before its too cold. I stay at 300 or so for the next 24 hours. After that, I'm just drying wet wood.
                    How's the Jenn Air working? I fretted over BBQs for ages. After reading so many poor reports on grills and warrantees, I opted for a lower-end, but none-the-less, nice AOG grill. I did get an optional infrared burner for my grill. That thing is incredible! Best decision I made in the whole project.
                    GJBingham
                    • Les
                      • Sep 2005
                      • 2945
                      #190
                      Re: Les' Build
                      How's the Jenn Air working?.
                      I?m liking it. I have an issue with water getting into the drip pan, but I have made no attempt at sealing it. When we get back to BBQ weather I am going to run a bead of silicon under the flanges. In regard to your heat loss ? are you insulated yet?
                      Les...
                      • gjbingham
                        • Sep 2007
                        • 2021
                        #191
                        Re: Les' Build
                        Yes, the oven's done. No worries, pizza and a load of bread and I've had it.
                        I've also saved the final installation of sink, BBQ and access doors (not to mention tile) until the weather is more forgiving. I've got water in my drawers, and no, I didn't pee!
                        GJBingham
                        • Les
                          • Sep 2005
                          • 2945
                          #192
                          Re: Les' Build
                          update...
                          I learned very quickly that one peel doesn't get it. Now I can have a line of four. This was scrap aluminum from work that I cut in the notorious "wood shop" They work pretty well to toss the pie in, after the first one, I didn't even notice I had no hair left on my hand. (I did notice the smell of burnt hair - note to self - buy BIG gloves)
                          Les...
                          • carloswlkr
                            • Nov 2006
                            • 97
                            #193
                            Re: Les' Build
                            Nice looking peels! But why did you go for short handles?
                            Beautiful oven and kitchen, by the way.
                            my work in progress:
                            http://www.fornobravo.com/forum/phot...dex.php?u=1031
                            • Les
                              • Sep 2005
                              • 2945
                              #194
                              Re: Les' Build
                              Carlos, I wanted something small and convenient to make the pizza?s on. After I slide them in the oven, I use a standard peel to cook them.
                              • sarah h
                                • Sep 2007
                                • 567
                                #195
                                Re: Les' Build
                                Or you could play ping-pong.
                                Just kidding - they look great Les, nice job!
                                I need to come up with a few more too - you're right, one just isn't enough.
                                Sarah
